OT: Distributor Poll
I am building a 1965 Ford 289 for my 49F1 and can't decide on what distributor I want to use. If I rebuild my old one and use a pertronix set up in it by the time I get done rebuilding it I will have more in it then if I buy one of those GM type HEI for a ford that has a one wire hook up. What have you used and why. Thanks
I'm using a one wire HEI by Proform, and a 100 amp one wire alternator from Speed Way. Easy peezy . I have never had any trouble except when I plugged the tach wire into the 12v plug, but that was my bad. There are several Ford HEI units on the market now but when I got mine Proform was the only one for Ford that I could find. I would do it again in a hot second. "EDIT" Tracy sorry I forgot the second part of your question. I went the HEI route for ease of trouble shooting, and a cleaner look under the hood. Plus Ive never been good with shooting trouble with a voltage regulator, coil, cpu(or points), distributor, and all the associated wiring.
on
I put reman Dura-Spark distributors in my kid's classic 289 Mustangs. They were super cheap from local parts places, bolted right in, work great and look stock.
You can use stock Ford modules or put in any other module you prefer. Easy to re-curve if you need to. You can also run a small or large cap setup.
When I went to a later roller cam engine in one of the stangs I just got a distributor for an 85 5.0 HO Mustang with carburetor and 5 speed trans. Has the correct advance curve, vacuum advance and the steel gear for the roller cam. Runs perfect and was cheap from local parts place. If you take the lower section of the cap off, a small cap and rotor goes right on and looks correct on an older engine.
jhweigel
34
09-19-2023 06:22 PM
jerryst
03-28-2017 02:25 PM
CRUNKED77FORD
08-25-2011 02:18 PM
