Name that sound - 85 460
Old 08-26-2016, 08:41 PM
kramttocs's Avatar
kramttocs
kramttocs is offline
This may be impossible to do via video but I figure it's worth a shot.
I've got an 85 460 (F350) that's making a rhythmic noise up front.
I am planning on replacing the power steering pump as it's been leaking ever since I got the truck (2 months ago) but wasn't sure if this noise was that or the water pump.
Like I said, may not be possible for anyone to identify without being in front of the truck but it's that whooshing/whirring noise that loops.
Appreciate any ideas.
Old 08-27-2016, 05:11 PM
KO1960's Avatar
KO1960
KO1960 is offline
A stethoscope can help to pinpoint the noise. It does sound like a bearing.
Old 08-27-2016, 05:32 PM
kramttocs's Avatar
kramttocs
I don't have one of those handy but would a pipe accomplish the same thing?
So my plan of attack is to first replaced what power steering pump, hose, and belts.
Then if I still have the noise I'll replace the water pump and fan clutch.
Is there a chance that a noise like that could be inside the engine? The short block was rebuilt about 2000 miles ago.
Old 08-28-2016, 11:26 AM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
Pull the belts off and start it up..... see if the noise goes away.
Old 08-28-2016, 12:04 PM
KO1960's Avatar
KO1960
KO1960 is offline
A stethoscope is $3.99 at Harbor Freight. I would find where the noise is coming from, before you start replacing parts. Good luck.
Old 08-28-2016, 02:49 PM
kramttocs's Avatar
kramttocs
Yeah, I'll pick one of those up the next time I get to the nearest town with a HF.
I pulled the belts off the p/s and waterpump and the noise went away. I really think it's the waterpump but I'll go ahead and replace the p/s first since I already have it on order, hook it up and see if the noise is still there.
Thanks
Old 09-11-2016, 09:00 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
With the belts off you should be able to spin the pulleys and feel/hear the bad ones.
Old 09-11-2016, 01:51 PM
kramttocs's Avatar
kramttocs
Thanks. Replaced the PS pump, high pressure hose, and all 3 belts. I am still keeping an eye on it but it appears that it took care of it. Also picked up a HF stethoscope for next time.
rwcmick
03-27-2011 04:20 PM
zombiesawyer
01-26-2011 10:55 PM
payner22
04-24-2005 01:07 AM
mybigredford
11-09-2004 09:47 PM
DaveMcQ2
1997 - 2003 F150
08-28-2004 08:33 AM
Quick Reply: Name that sound - 85 460
