Truck from the factory was 1976 f150 camper special, 2wd long bed, Dana 61 rear. Goin crown Vic front swap with 9 inch rear. FE engine before and after
Any guesses?
I hope you are right. I was hoping for under 4500. Also forgot a few things. Truck is currently auto c6, swapping to c4. Engine will get aluminum heads and intake.
If you're near an agricultural or industrial area, there should be public scales that will tell you exactly. In Yuma, we have a lot of snowbirds dragging around large trailers, sometimes fifth wheels, and many have diesel pushers. They need the scales to check their balance, I presume
Your county landfill usually charges based on weight, I'll bet. Take a load in to be dumped, they will weigh coming in and when departing. Might cost ya ten bucks, but you'll know for sure.
2x.. I dumped a load of construction debris a couple of weekends ago. Surprisingly, outbound my 01 4wd SuperCrew weighed in about 5,400 pounds.
