Need help with parts identification
#1) Amplifier assy., EGR Vacuum P/N D5FZ-9E451-B marked D52E-B1A, B2A, B3A
#2) Valve assy., EGR solenoid vacuum. Several different P/N's. There should be an engineering number on it. Post it and I'll cross it over.
#3) Not sure what that one is. Is it part of the carb or part of the EGR spacer? Is there a number on it?
Mike o0o0,Thanks for the reply. I am not so interested in part numbers as I am in what these parts do, how they are related to each other. (interact) I notice they are all connected one way of another by one of more vacuum lines. . . .
Part # 3 in the photo connects to a rod that goes underneath the choke assembly, so these all have something to do with choke control via heat/warm engine/cold engine/vacuum/on/off, etc. Just want to learn.
#3 Could be choke pull-off, I'm not all that familiar with the Motorcraft 4300 carb. What's throwing me is I cant see any linkage, maybe that's hidden by the way it's mounted.
Mikeo0o0
Well I believe #3 is the choke pull-off. However, #1 & #2 are not part of the EGR system, as they are not connected to it in any way. 1&2 have vacuum lines that run from carb body vacuum to #1 then to #2 then to #3 in that order. So, again, I am trying to understand how these three components work together to actuate the choke pull off....
None taken.
On the vacuum amplifier the numbers marked D52E-B1A, B2A, or B3A should be on the part. On plastic parts it can be either molded into the part or printed on it or a combination of the two.
And these aren't actually "part numbers". Ford hasn't put a part number on anything since the early 50's. These are "engineering numbers". It's not unusual for several different engineering numbers to cross over to one part number.
