Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 N600 axle Oil seal
Old 08-25-2016, 04:39 PM
Troubleuk's Avatar
Troubleuk
Troubleuk is offline
Hey
Usually I research and find this stuff myself but this time I am stumped!!
I put new rear brakes on her and one of the oil seals looked a little suspect, well 20miles later its dribbling oil down the Tyre out of the drum!
I could do with the part numbers for the all the seasl that go kind of wheel end of the axle please I think there is 3 in total.
Body tag reads:
N60CUA44006
163 J N600 F81 A F8L
19500 164 3800 34
any help greatly appreciated!
and here she is!
Old 08-25-2016, 06:42 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Exclamation 1967 N600 Axle Oil Seal
Warranty Plate:
N60CUA44006 / WB: 163 / COLOR: J / MODEL: N600 / BODY: F81 / TRANS: A / AXLE: F8L / MAX GVW LBS: 19500 / CERT NET HP: 164 / RPM: 3800 / DSO: 34
N60 = N600 (gas).
C = 330 2V M/D FT engine.
U = Louisville KY Assembly Plant.
A44006 = 1967 .. assembled November 1966.
163" Wheelbase.
J = Rangoon Red.
N600 (gas) .. 19,500 lbs. GVWR
F81: F = Black all Vinyl / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F8L:
F8 = Eaton model 13802 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
L = Ford-Rockwell(Timken) 6,000 lbs. Capacity Front Axle with H/D front brakes.
19,500 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
34 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
Pic: The pinion seal is basic part number 4676 .. The axle seals are basic part number 1174 .. but...
I need to know the size of the rear brake shoes to list the part number.
Old 08-25-2016, 07:20 PM
Troubleuk's Avatar
Troubleuk
Do you need the diameter of shoes?
I wanted to get the seals before taking it apart!!! Ah well I will take it apart tomorrow😎
Thank you for the info so far it's great I always wondered what colour it was
Old 08-25-2016, 07:24 PM
Troubleuk's Avatar
Troubleuk
I think the seal that is shot is the one that is actually in the brake drum/hub.
Old 08-26-2016, 07:44 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The old seals with probably have a part number on them. Not necessarily a Ford part number, but if it's National or some other brand, you can usually cross-reference them at Napa or another good parts store that can lookup part numbers directly or in books
Old 08-26-2016, 08:17 AM
Troubleuk's Avatar
Troubleuk
Thanks for the info I was just trying to get the seals before I take it apart, ah well🤗
At least I know it's rangoon red now!!
Old 08-26-2016, 08:21 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Oh, I know the feeling
Old 08-27-2016, 10:10 AM
Troubleuk's Avatar
Troubleuk
Ok shoe diameter 15" and the shoes are 4.5" wide drum contact area is 5".
If you have part numbers that would be great the end axle seal just had C/R stamped on it.
Thank you
Old 08-28-2016, 10:48 AM
NumberDummy
2) B6Q-1175-A .. Rear Seal-Inner / Timken part number: A-1205-K-739 / 4 3/4" O.D. x 3 7/16" I.D. x 9/16" thick / Obsolete
SOEBY MOTOR CO. in Walhalla ND has 4 = 701-549-3711.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 12 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 56 = 800-543-4959.
2) B6T-1181-A .. Rear Seal-Outer / Timken part number: A-1205-M-741 / 5 7/8" O.D. x 2 3/8" I.D. x 13/32" thick / Obsolete
SOEBY MOTOR CO. has 1.
FRIESEN FORD in Aurora NE has 2 = 402-694-3111.
CARPENTER NOS OBSOLETE PARTS has 10.
Old 08-28-2016, 04:55 PM
Troubleuk's Avatar
Troubleuk
Perfect thank you!! you don't happen to know the color of the silver on the front end by chance so I can respray it??
Old 09-04-2016, 04:48 PM
elpound's Avatar
elpound
elpound is offline
I really like your truck. Looks great! Your floor mat looks a lot better than mine, and my shifter boot is toast as well. Does anyone know if the tall hump floor mats for the regular 65-66 f trucks will fit these N series Fords? As for the opening on the shifter it measures 11 3/4 x 7 1/2. I'm looking at having one sewn up in vinyl fabric.
Old 09-05-2016, 09:50 AM
NumberDummy
1963/69 N500/1100's use a unique floor mat, it's not the same as any F series truck.
Old 09-05-2016, 02:29 PM
elpound's Avatar
elpound
elpound is offline
Well that's not the answer I was hoping for. Thanks for letting me know that before I went and bought one.
Mii
Large Truck
15
09-22-2021 06:38 PM
bmoran4
16
07-11-2018 05:14 PM
Jeepcamp
08-30-2016 11:53 AM
Jeepcamp
08-30-2016 08:30 AM
fisherman_chuck
01-04-2016 11:28 AM
Quick Reply: 1966 N600 axle Oil seal
