1966 N600 axle Oil seal
Hey
Usually I research and find this stuff myself but this time I am stumped!!
I put new rear brakes on her and one of the oil seals looked a little suspect, well 20miles later its dribbling oil down the Tyre out of the drum!
I could do with the part numbers for the all the seasl that go kind of wheel end of the axle please I think there is 3 in total.
Body tag reads:
N60CUA44006
163 J N600 F81 A F8L
19500 164 3800 34
any help greatly appreciated!
and here she is!
1967 N600 Axle Oil Seal
Warranty Plate:
N60CUA44006 / WB: 163 / COLOR: J / MODEL: N600 / BODY: F81 / TRANS: A / AXLE: F8L / MAX GVW LBS: 19500 / CERT NET HP: 164 / RPM: 3800 / DSO: 34
Warranty Plate:
C = 330 2V M/D FT engine.
U = Louisville KY Assembly Plant.
A44006 = 1967 .. assembled November 1966.
163" Wheelbase.
J = Rangoon Red.
N600 (gas) .. 19,500 lbs. GVWR
F81: F = Black all Vinyl / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F8L:
F8 = Eaton model 13802 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
L = Ford-Rockwell(Timken) 6,000 lbs. Capacity Front Axle with H/D front brakes.
19,500 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
34 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
Pic: The pinion seal is basic part number 4676 .. The axle seals are basic part number 1174 .. but...
I need to know the size of the rear brake shoes to list the part number.
SOEBY MOTOR CO. in Walhalla ND has 4 = 701-549-3711.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 12 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 56 = 800-543-4959.
2) B6T-1181-A .. Rear Seal-Outer / Timken part number: A-1205-M-741 / 5 7/8" O.D. x 2 3/8" I.D. x 13/32" thick / Obsolete
SOEBY MOTOR CO. has 1.
FRIESEN FORD in Aurora NE has 2 = 402-694-3111.
CARPENTER NOS OBSOLETE PARTS has 10.
I really like your truck. Looks great! Your floor mat looks a lot better than mine, and my shifter boot is toast as well. Does anyone know if the tall hump floor mats for the regular 65-66 f trucks will fit these N series Fords? As for the opening on the shifter it measures 11 3/4 x 7 1/2. I'm looking at having one sewn up in vinyl fabric.
bmoran4
16
07-11-2018 05:14 PM
Jeepcamp
08-30-2016 11:53 AM
Jeepcamp
08-30-2016 08:30 AM
fisherman_chuck
01-04-2016 11:28 AM
