Changing my fuel filter out just a minute ago. Got the bowl drained and took the old filter out and cycled the key to the on position to fill the bowl bit it won't do nothing. It doesn't fill it. I had to manually fill it up. Truck is running fine. No issues. Could my electric pump in the tank be bad?
Don't drain the bowl unless you are cleaning it out.
If you drain it, you can fill it back up or crank it over for a bit to refill
insert new filter slowly so it wont over flow
Drain, install filter, crank to fill/start. DON'T fill the bowl completely before installing the filter; it'll obviously overflow. Even if you partly fill it first, it's a guess how much you want to fill it to avoid it overflowing when you install the filter.
