NashvegasMatt's build journey 72'
Gonna have to address the motor temp issue soon. I know it's cooling off outside but I think it still needs to be addressed. It's not totally overheating into the danger zone but after about 45 minutes this is where it lands. Coolant level seems ok. Thermostat maybe? How does one test a thermostat? Guess we shall find out.
Gonna have to address the motor temp issue soon. I know it's cooling off outside but I think it still needs to be addressed. It's totally overheating but after about 45 minutes this is where it lands. Coolant level seems ok. Thermostat maybe? How does one test a thermostat? Guess we shall find out.
More better if our OEM gauges had graduations referenced to an actual temperature.
This is why your engine is running hot. The alternator and the P/S should be on separate belts. The way it is now, the belt is not around the water pump pulley enough. The belt is slipping more than driving the water pump.
<a href="http://s957.photobucket.com/user/mattshorr/media/F100/4376DF78-C035-4DBC-AA28-000D01D6C511_zpsawdlbvqy.jpg.html" target="_blank">
<a href="http://s957.photobucket.com/user/mattshorr/media/F100/35CC4677-932E-4859-BC2E-0DD8E81B5275_zpsndwoftyn.jpg.html" target="_blank">Attachment 215032
NashvegasMattView Public ProfileView GallerySend a private message to NashvegasMattSend email to NashvegasMattFind all posts by NashvegasMattAdd NashvegasMatt to Your Contacts
The alternator needs a shorter belt just for it. The pump has to come forward so it's belt will ride in the front sheave of the crank and water pump pulleys. That P/S pump bracket looks weird to me. The PO must have gotten one off the wrong engine and modified it. The part number on that bracket was D0AZ3A732C but none around the NOS companies or any dealers. Is there any Bumps with a 302 in a local wrecking yard? Or, that bracket was also on:
70/72 full size Ford cars with a 302. 1970 with a 351 also.
70/72 Torino 302 (72 w/o A/C). Also 70/72 351C
71/72 Mustangs 302 and 351. Also 351C with A/C.
May fit Mercs also but I can't check right now. Gotta Go.
Anyone have pics of this 2 belt setup on my year style?
There's a handful of pull-a-parts here in town so I'll have to check it out.
#29
So there you go. See Jeff #24 above. There is not one in 1000 mechanics that could make that call. Well done Jeff. That motor is obviously wrong and you spotted it.
OP: With a chopsaw and metal blade and a length of 1/2 galvanized pipe you can push the pump forward to engage the pulley. Also, don't test the thermostat, dump it and buy a top quality Stant or Robertshaw or anything of quality and replace it. The auto supply store will give you a belt to fit your modified pump if you take a string measurement down.
#30
Ironically I read a ton of info here on this forum about overheating and never ran into this as a solution.... then again, the motor may not have been set up wrong. This may also explain why autozone and oreillys couldn't find the V belt when I went in to ask for a repplacement.
ok. this seems easy enough. Although I can't find a picture to support it, my crank sure enough has 2 grooves. Luckily I work somewhere that sells black galvanized pipe and has a cutter/threader so I can make them all identical. Wonder what the best way to gauge how long the spacers need to be? Measure the distance on the bottom crank pulley belt between the center of where the belt is now and the new groove? sound like a plan?
