Screws at top of door panel?
Old 08-25-2016, 12:16 AM
tab a's Avatar
tab a
tab a is offline
There are 2 screws at the top of both door panels. Well--there should be, but all 4 of mine are gone. What's left are 4 holes, that would need huge sheet metal screws. I'm guessing there should be some kind of plastic insert, or similar, in those 1/4" or so holes? Available somewhere?
Thanks.
1998 4.6l
Old 08-25-2016, 04:35 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
there should be 2-3 sheetmetal screws at the bottom and a couple behind the door handle and arm rest / electric window switch area... at the top and around the sides you should have a big plastic insert / plastic screw that attaches to the back of the panel and pushes into the big hole in the steel door inner wall.
Old 08-25-2016, 04:37 PM
steve(ill)'s Avatar
steve(ill)
Old 08-25-2016, 04:38 PM
steve(ill)'s Avatar
steve(ill)
Old 09-05-2016, 12:14 AM
tab a's Avatar
tab a
tab a is offline
Thanks for the links.
Video I've seen seems to show metal screws in this location. Maybe varies with years/models?
Old 09-05-2016, 11:34 PM
Torky2's Avatar
Torky2
Torky2 is offline
I have a 1997 3-door. Can you be much more specific about which doors, and exactly where (and like inside or outside of the weatherstripping, etc.), as I'm not seeing any 1/4" holes on mine.
Was any Paintless Dent Repair done on this truck? Like plugs to fill the holes that were drilled for tool entry popped off, or were never installed?
Old 09-10-2016, 07:27 AM
tab a's Avatar
tab a
tab a is offline
There's a good view of the screws, in this video, at about 2:07.
Thanks.
Matt1966
16
03-01-2022 08:56 PM
MR KROGOTH
05-03-2019 06:54 PM
iszatso
Aerostar
02-12-2015 10:21 PM
pizalm
07-10-2004 07:35 PM
176ford
04-16-2004 10:17 AM
Quick Reply: Screws at top of door panel?
