High pitch squeal
I don't think the noise is coming from the turbo.
When wheels rub, noise is normally not high pitch, and it would not be consistent. Also, power loss would be felt.
Push the compressor wheel all the way to one side while rotate it. Also, push and pull on the compressor wheel. If you don't hear anything funny, it's probably not the turbo.
good pics, there is definitely some carnage on the compressor housing but the wheel doesn't show any damage in the pics. Maybe the scars were done from the previous owner or something?
Yeah but mine makes this noise sitting in park at 23-2500 rpm
I was trying to help the OP and was aware you are trying to resolve a squeal issue as well. I wish I had something to offer on a parked vehicle, but I come up empty on that one. What I have found there will be someone come along with the answer you are looking for.
Good luck.
Oldboots
Good luck.
Oldboots
#28
This is the same boot that blew off pulling a hill with a load... Sounded like a shotgun when it happened.
Is it possible that that rubbed spot may be opening up a little under high RPMs and leaking? Going to Ford to get boots gotta have truck back on
road Monday. I may order the other kits and do them all later.
#29
Good luck.
Oldboots
Good luck.
Oldboots
#30
intercooler duct passenger side.
While you are searching for the answer to your squeal, check your aluminum intercooler tubes. There are a couple of wiring Harnes that lay on the tubes. The Harnes WILL ware a hole thru the tubes.
