Cab lights leaking caused GEM to Freak out
Title says it all I had my windshield resealed and I thought I had no more water leaks....WRONG !!! So one day after heavy rains my GEM unit started to freak out: OD light blinking, speedo bouncing up & down, door locks not working with key fob, radio staying on after key is out and other odd things. So I pulled the trim off the drivers side windshield post put some paper towels up in there. The clearance lights on top of the cab were leaking from both base & lens. I also found that the overhead console problem was a resistor is loose.
So I thought well since I need to R&I the lights I'll drop the headliner and insulate the roof. Because Blackie is like a oven after sitting in the sun. So I turned to Eastwood products and Eastwood's X Mat #15825 Hood Insulation is 1/4" thick and will fit under the headliner without causing an issue. Here is where I messed up I have a crew cab and I did not do the math. I had only bought 1 roll and to do it right it would take about 1 1/2 rolls. So I wasn't able to insulate the roof the way I was planning but it was still a huge improvement in keeping the heat out. I took out a temp gun and on a 88* day the roof skin on the inside was 137* and where I had the X Mat it was 107*.
30* difference is really good and lives up to Eastwoods claims !
Here you can see that even dirt was getting under the cab lights.
So I used Permatex Clear RTV Silicone #80050 to reseal housings to cab and lens to the housings after cleaning everything.
Also if you look closely you can see I used metal duct tape to seal up all holes in the roof reinforcement. Did it help ??? Did it hurt NO.
You can in this photo that I ran out of X Mat and used left over pieces where I could. OOpppsss Oh well... it is still better then nothing.
I also had bought a box of 12x12 XMat #15842 to finish the front doors with. Well once again I wasn't thinking that day and it takes about 4 1/2 mats to do one door. So I was able to finish the drivers door skin and I only had 2 mats to put on the other front door skin.
Well the base of the clearance lights are made of plastic and have 2 studs that screw into the plastic and the other end of the studs have machine threads and a 10mm nut that screws on inside the roof. The base has a foam seal on the bottom of the base to seal it to the roof. I did NOT remove the foam seals since they were sealed well to the base but I did use the RTV silicone on and around the foam gasket.
**Warning** The studs in the base will want to come loose before the nut on the bottom side of roof does. So what I did to get the nuts loose without the studs coming loose from base was I used a 10mm wrench and the studs have a torx end so I used a torx socket to hold the stud. Also used the RTV silicone on the threads and hole where the lens mounts.
Now on the lens I found the factory gasket inside the base to be worthless so I removed them and used the RTV silicone to seal the outer edges on the base.
BIGTRUCKBIGRV
1999 to 2016 Super Duty
13
06-15-2014 11:13 PM
Lukes66
02-15-2013 11:17 AM
