I believe the larger yellow wire is for an optional trailer towing package and perhaps the other one [if always hot] is for the optional under hood light.
That makes sense. I'll have to check the voltage. The yellow and grey one up above almost look like they were meant to be plugged in together.
Light green/yellow-stripe = always-on, fused accessory feed for the underhood lamp as David said.
The other one, hard to see your picture but if it's a thick, yellow wire (maybe with a blue plug) then yes, that was supplied with trailer towing/camper packages.
