Mitsubishi Starter Yay or Nay?
The real problem is that there are a lot of really crummy rebuilds out there; it's a crapshoot what you'll get at the autoparts store. One might last a month(due to poor machining of the brush contacts eating the brushes up), while the next might last years.
Also, our trucks have a standard SAE #2(IIRC) starter pattern, so you'll find starters from other engines which fit. As long as it's a gear-reduction unit of the right physical size, it'll probably work.
On top of all that, Realslow has the right idea here: My tan 88 will fire off in about 5 seconds, with proper glow plug use. My blue 88 takes about 20 seconds of cranking(and two cyclings of glow plugs), due to a worn out IP and possible fuel bleed down(and probably other issues). Which do you think will have a longer lasting starter?
true true .. my orylies starters with lifetime warranty are shotty rebuilds .. keep the receipt
the brushes are ok in the second one .. but poor machined nose gears .. cutoff wheel repaired and it works good now ..
always cranks 2 seconds only with tiny spirt ether and zero working glowplugs
I do not like glow plugs but I live in the south but people up north say you have to have them.
I have read where people will install ether injection on these but when I use ether the engine tries to fire backwards.
Does anybody have a solution to this?
I personally hate ether. I think it's garbage on these high compression diesels. Modern ones works great for but these ones are way too touchy about it.
I recently found that gasoline in a spray bottle works REALLY REALLY well and won't pre-detonate. Was trying to bleed my IP after a swap and it will actually run the engine around idle speed or a bit faster if you pump fast enough, haha. Bled the injectors in just 10 seconds!!!
And to stay on topic...it's also really really easy on the starter.
I went through four Mitsubishi starters in less than a year, got a denso and its made it a year so far. Even whips over like a powerstroke. Something none of my Mitsubishi starters would do. Maybe I just got duds. None of them actually died. They just began to drag. I'm hell on starters though. With a lifetime warranty I don't cut them any slack.
One thing I have heard which is good to keep in mind in general probably anyway, is don't forget we are not comparing apples to apples when replacing a new starter with an old tired starter. Most threads you read go like this, which starter should I put in, puts new starter in, regardless of which one, wow it cranks crazy fast. So I don't know of anyone who has had one style of starter in new, then another style new to compare.
Devin
Devin
#30
WaveyDavey1980
04-18-2019 09:31 PM
awils961
01-25-2011 05:05 PM
