Differential fluids
08-22-2016, 01:07 PM
Differential fluids
Just wanted to see if you all can confirm something for me.
Rear Diff, I have a 4.10 LS (C5 Code). Using Mobile 1 LS 75w-140 oil. Take 3.5 quarts?
08-22-2016, 02:21 PM
on
That sounds about right for my 96. Fill it up till the overflow port says "enough!"
08-22-2016, 02:25 PM
Thanks, rear looked pretty good inside. This look like a LS to ya'll? tag says 4L10 on it and the door jam shows a "C5" code:
08-22-2016, 03:01 PM
I don't see no clutches from that angle pic
08-22-2016, 03:02 PM
Thats what i think when i look at it.....surprised by the tag an the C5 code in the door jam sticker.
08-22-2016, 03:13 PM
This is the tag - how would you read it?
08-22-2016, 03:14 PM
It reads:
S 132 N
4L10 10 2 6J06
08-22-2016, 03:27 PM
It's an open geaset, just like I had prior to a Detroit Tru-Trak.
On fill. I agree with Airstreamer, fill it 'till it comes out the level hole. I fill mine from a 5 gallon pail with a handpump.
08-22-2016, 03:29 PM
And now I have another issue, the bolt for the fill on the front of the axle is totally stripped, after two hours we cannot get it out.
What options do i have?
08-22-2016, 03:30 PM
Quote:
Originally Posted by
PSU4ME
Have you tried heat yet?
08-22-2016, 03:41 PM
Thanks for the ID....cool site.
I'm told it is a lost cause when asked if he used heat. Assuming it is busted, any ideas?
08-22-2016, 03:46 PM
why not fill by the over flow port on the cover?
08-22-2016, 03:55 PM
Through the vent? Yes i think we could do that, I would just need to fill based on recommended capacity. Would you think 3.25 or 3.5 quarts to add?
