Removing fan clutch 1984 I-6
08-21-2016, 03:47 PM
on
Are there any tricks to removing the fan that will work without buying a $50 pulley holding tool.
I've tried everything from binding the crank pulley, to hitting the wrench with a hammer thing to break the fan clutch nut loose. Nothing has worked so far.
1984 F150 with the straight 6. Has a fan clutch, despite the Chiltons manual saying it shouldn't have one.
08-21-2016, 03:53 PM
If it's v-belt it's left handed thread.
Some get lucky just holding the belt tight and smacking the wrench.
A little heat on the hex may help as well, some use loctite when assembling them heat releases loctite.
EDIT
325F degrees is the release temperature for Red 271.
-Enjoy
fh : )_~
08-21-2016, 03:55 PM
Do you have any metal bar laying around that you could drill a hole in and put it under one of the pulley bolts?
Never worked on a six, but my diesel has one of those aggravating spin on clutch fans. I had to make a holder for it and that's what I did.
08-21-2016, 07:28 PM
on
I've seen conflicting information on whether it's left or right hand thread. I'll try turning it the other way.
I do have a bar that could work... I'd have to pound one end flat, might enlist my brother-in-law's forge to help with that.
I appreciate the info!
08-21-2016, 07:32 PM
They come off the same way they rotate ...
V-Belt rotates clockwise, thus left handed threads.
Serpentine rotates counter clockwise, thus right handed threads.
-Enjoy
fh : )_~
08-22-2016, 08:56 AM
08-22-2016, 05:08 PM
My original fan shroud on my diesel says "caution fan" and it also says "left hand thread" on it.
Hanoverfiste
1997 - 2003 F150
10-10-2009 06:44 AM
FARM69
05-07-2008 03:23 PM
quicklook2
19
12-19-2006 06:54 PM
Jack-Iowa
10-16-2006 07:00 PM
Ultramagdan
1997 - 2003 F150
02-08-2003 09:00 PM
