AC compressor should turn freely?
I just bought a 96 f250 5.8
Upon driving home, i tried the ac again and the ac clutch started to smoke. I replaced the clutch with one from autozone, but when I tried it again, it made a screaming death noise upon clutch engagement.
Is my compressor seized?
I tried to turn the clutch (not the pulley, that spins fine) by tapping one of the slots and bolts with a screwdriver/hammer. It was firmly locked in place.
If the compressor was OK, would it have turned easily?
If I need to replace the ac pump, who sells a good/cheap/reliable one?
Put a socket wrench on the compressor shaft bolt. If you can't turn it clockwise with relative ease, it's dead. Usual failure mode is seized tight, or able to rock it back and forth a bit, but then hits a solid stop. Either way, that is an internal catastrophic failure.
Your 1996 5.8 F-250 will be the same A/C parts as my 1994 5.8 Bronco. All refrigerant-related parts are under the hood on those year trucks - GREAT!
Here are a few relevant threads if yours is deceased:
https://www.ford-trucks.com/forums/1...6-f250-hd.html
https://www.ford-trucks.com/forums/1...ant-lines.html
https://www.ford-trucks.com/forums/1...-ac-parts.html
factory-ac-parts.html[/url]
Should I also buy a new Condenser? Evaporator? All the many hoses?
Anyway, I'll read your links, unless I'm too distracted by the women's high jump finals...
Oh, and thanks Detroit for putting all the AC stuff under the hood, so much space compared to my GTI!
Received 3,103 Likes
on
IIRC, true "Black Death" was applicable to R-12 mineral-oil based systems.
You've got typical failed compressor stuff. Oil, cooked oil, shards of aluminum, steel, hard shoe material, from big to very tiny. Aluminum from pistons and cylinder bores, steel from swash plate, shoe material like carbide.
Your compressor's last seconds of life were painful, but it's at peace now...
You can see why the condenser, manifold hose assembly, etc. needs to be replaced!
Replace the evaporator too. I would not depend on a filter screen to guaranty that nothing went in the evap. And since everything else is going to be new, why leave the old evap there? Firewall Forward!
Rainman5150
05-29-2013 01:43 PM
MrRogers
07-14-2009 09:11 PM
ncvote
04-24-2005 02:59 PM
