2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Tow Technology Package
Old 08-20-2016, 03:58 PM
gascan's Avatar
gascan
gascan is offline
Unhappy Tow Technology Package
Hello all,
I attended the 2017 Super Duty Drive Tour in San Antonio this morning. It was the first time I have been able to see the new trucks in person. I drove a 450 Platinum and then had a chance to explore the 360 camera systems and reverse backup system on a 350 King Ranch SRW. Very nice trucks and I can't wait for mine to get here.
However, I did see something that I was not happy about... I have ordered a truck with the 5th Wheel/Gooseneck Hitch Prep Package, Tow Technology Package and with the Trailer Camera Prep Kit as I want a rear facing camera for the back of my 5th wheel camper. The problem I saw on the 350 King Ranch (which had the camera system, the external camera for the trailer, and the 5th wheel prep) is that there is no place to plug in the external trailer camera in the bed of the truck. The 5th wheel prep package installs an outlet for the lights/brakes but there is no outlet in the bed sidewall for the camera. The only camera outlet is down on the bumper. This is not good. If you install a wired camera system on a 5th wheel camper (which I have done on two different 5th wheel campers), you will want to run the camera cabling all the way to 5th wheel pinbox just like the lights/brakes cabling. Now with the Ford has done this, I will have to run the camera cable out of the pinbox across my tailgate and down to the bumper outlet. Duh! This is just short sighted and a bad decision.
So Ford had idea and a potentially great solution and didn't it right. Uhhggg!!
-Chris
Old 08-20-2016, 04:06 PM
System's Avatar
System
System is offline
Prolocutor
Received 1,198 Likes on 573 Posts
Chris, we've discussed this before and I'd say we all agree with you. That was a major oversight by Ford. Some have suggested that instead of mounting the camera plug in the bumper in place of the 4 pin that you instead make a new hole in the bed for it. Or perhaps enlarge the existing hole that's there for the in bed 7 way.
Old 08-20-2016, 04:07 PM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
This has been discussed before. Whether Ford does anything about it waits to be seen. Yes it makes no sense since most that tow and would want the camera will have a gooseneck or fifth wheel.
johndeerefarmer
Dang you beat me by a minute!
Old 08-20-2016, 04:08 PM
gascan's Avatar
gascan
gascan is offline
Sorry - I didn't realize there was a thread already on this. Thanks.
Old 08-20-2016, 04:09 PM
System's Avatar
System
System is offline
Prolocutor
There wasn't. It was brought up in a general thread a while back. I think it was Josh's experience thread. No worries.
System's Avatar
System
System is offline
Prolocutor
I was typing as fast as possible as I knew you'd be right there at the finish line!
Old 08-20-2016, 04:24 PM
lts's Avatar
lts
lts is offline
Gascan,
I'm glad you pointed this out, as I also had missed the previous discussion regarding this issue. Sounds like the gurus have a good fix for this though, shouldn't be too much trouble to move it into the bed near the 7-way plug. Still have to deal with the hole left in the bumper though?
BTW, I thought I saw a post a few days back that said the cable for the trailer camera was only long enough for a 30' or so trailer. Anyone know if this is the case? Sorry, I'm trying to get up to speed but not much time to keep up with all the great info on this forum...
Thanks,
Gentry
Old 08-20-2016, 04:30 PM
gascan's Avatar
gascan
gascan is offline
Originally Posted by lts
Gascan,
Thanks,
Gentry
Yeah, I was already hoping I could move the outlet to the bed assuming there is enough cable lengths and room to route it. I installed a connector in my current 2011 for a camera system so it can be done.
As for cable length, according to the rep I spoke with this morning the "Trailer Camera Prep Kit" comes with 3 cable lengths one of them being 50 feet. I hope it long enough. My RV is 40 feet but I want to mount the camera at top of the rear and it is another 10 feet from the bottom of the RV to the top as I would run the camera along the bottom of RV frame. Worst case - I can splice in some extra length.
As well as 2017 is it sure seems like Ford didn't quite think this one through... Very frustrating. Net-Net - I think I can work around it.
-Chris
Old 08-20-2016, 04:38 PM
gascan's Avatar
gascan
gascan is offline
This is the Quick Connect/Disconnect system I have in my current truck.
Rearview Safety Quick Connect
Anyone know if the pinouts for the Ford camera outlet are available? Might be able use the above system - cut and splice this in and make it work. I can't image the Ford camera system needing more than 6 wires which is what this system is.
-Chris
lts's Avatar
lts
lts is offline
Yeah, I'm in the same boat regarding the cable length (RV is about 42.5' long). But I can solder & heat shrink with the best of them so no worries.
Can't wait till it gets here!
Old 08-20-2016, 04:39 PM
Rasalas's Avatar
Rasalas
Rasalas is offline
Hello all,
-Chris
There has been talk that the trailer tow camera has 5' lengths of extensions for the cable. It might be a nuisance but one or two of these should alleviate the problem until a better solution (IE a plug in the box) comes around. Press your dealer for a free one.
Old 08-20-2016, 04:40 PM
gascan's Avatar
gascan
gascan is offline
... But I can solder & heat shrink with the best of them so no worries.
Amen brother - same here!!
-Chris
Old 08-20-2016, 05:12 PM
System's Avatar
System
System is offline
Prolocutor
Gascan,
Gentry, there won't be a hole left in the bumper. When you order the trailer camera kit, it comes with the bumper outlet for the camera. This outlet replaces the stock 4 way plug. So, instead of replacing the 4 way with the camera plug, you leave the 4 way and mount the camera plug in bed. Connection method hasn't been established but shouldn't be too hard...
Old 08-20-2016, 05:19 PM
EightySecond's Avatar
EightySecond
EightySecond is offline
Heads are exploding around here when guys are reading "3 different cable lengths and 1 of the being 50'..."
What do we believe????? LOL
Quick Reply: Tow Technology Package
