I hate my truck with a passion
#31
You can take the ECU connector off and do a continuity check between the self test connector pins and the corresponding ECU connector pins. If all that checks out, then the computer is definitely broken if it won't go into self test mode.
Could you take some pictures of the inside of your computer, specifically around the capacitors (metal cans sticking up off the board)
#32
I took pictures of it but can't figure out how to put them on here. I'm guessing the multimeter has to be in ohms? Just stick the positive on the harness connector and the negative on the computer connection? Im still not the greatest with electrical stuff yet. Good with directions though.
#33
Ohms would work, but many digital multi meters have a continuity mode where it makes a beep sound if you touch the two probes together. That makes diagnostics faster and easier.
If you have the pictures on your computer or phone, it's easy to get them on here. When you make a post, look in the settings bar (where the font size/color, etc.. is) above the text box. You'll see a little yellow square with black "mountains" in it. Click that, and it will allow you to upload a picture.
#35
#36
#38
#39
Ok I just looked up failed capacitors I was expecting some kind of goo leaking out of them but it's either a yellow or orange liquid right? I noticed some orange stains on the board when I had it out but I didn't think anything about it. I don't know I guess I'll have to pull it back out. If I end up replacing it are them megasquirt systems any good?
#40
#41
#43
