what year 460 i have?
Old 08-20-2016, 12:57 PM
b79rag's Avatar
b79rag
b79rag is offline
Trying to find out what year motor it is so i can get the correct parts for it.
Here are some pics of motor and numbers i found on it.
Motor is in a 76 f250 crew cab
Old 08-20-2016, 01:38 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
That is a D9TE Block 1979 castingg configuration. The D9 blocks were used until end of 460 production. D9TE 460 has an externally balanced rotating assembly all other 429 and 460's have internally balanced assembly. The externally balanced rotating assembly utilizes a crankshaft that has slightly smaller counterweights. This apparently was done to so that the cylinders of the D9TE block could be extended about .200" deeper towards the crankcase. The cylinders of the D9TE blocks are lengthened because this block was to double as a med duty truck block, and the med duty truck rotating assemblies consisted of a very deep skirt piston that benefitted from the newly extended cylinder walls for support.
Earlier crankshaftsfts will not fit in the D9TE block as the counter weights will not clear the bottom of the cylinders.
Old 08-24-2016, 05:20 PM
b79rag's Avatar
b79rag
b79rag is offline
Thank for the info, it did help alittle, but had to guess what year it was to get the right fuel pump.
nofortunateson
12-10-2007 04:27 PM
Firemudder
03-28-2007 07:38 PM
rmcgraw351
12-04-2003 01:55 PM
Quick Reply: what year 460 i have?
