94.5 psd elecrtical issue
now that the 88 460 is running i am starting to fix little issues with my 1994.5 psd , the in cab fuse block , has no power to certain fuses , like the radio , dash lights , power point , no fuses are blown just no power , i dont see any frayed or melted or rat chewed wires , is there a wire diagram on here some where , or any ideas on where to start tracing this , thx
hi guys have not done much since i posted this ,, the maxi fuses are good , and i havnt found the problem yet , but i did run new cables to the starter and batteries as i was seeing a voltage drop on amp meter ,, that took care of that problem ,,,,,, ok i still have no power to parts of in cab fuse block,, am NOT blowing fuse's .. but if i turn on head lights the engine kills , run turn signals engine stumbles , i know there has to be a short some where , but killing the engine ??
Nateairman had a similar problem with the radio and dash light in this thread https://www.ford-trucks.com/forums/1...ig-fix-10.html
In post 148, he traced it to a bad ground at the passenger side kick panel.
Ground point on the cab had rusted off. Remove both interior kick panels.
shorty2tall
09-12-2010 12:51 AM
64customcabman
05-17-2002 10:09 AM
