AFTERMARKET TAILGATE QUALITY--NEED INFO
So my 78 F150 is at the body shop getting the side panel on the bed replaced and I'd like them to pull a dent out of the top of the tailgate and repaint it at the same time they replace the side panel. The tailgate has a few small dings here and there, besides the dent on the top of the tailgate, and is ever so slightly bowed just a little bit, but not too bad at all. Long story short, the guy at the body shop said it would cost as much or even a little more (depending on how much work it takes to pull the dent) than it is to buy a new tailgate and just paint it. I'd rather have a new tailgate because then all the little dings and blemishes that my old tailgate has wouldn't be there in the new one. With that said, I've been looking at tailgates from LMC Truck, Jeff's Bronco Graveyard, Blue Oval Truck Parts, and Auto Krafters.
I have a few questions...
1) Are there any new tailgates available that are NOT imported that are OEM quality? If so, who has them?
2) What is the gauge of an OEM Tailgate?
3) What is the gauge of an imported tailgate?
4) Has anyone used an imported tailgate? If so, how did it fit and was it as strong as the OEM?
5) What type of metal is used in the OEM tailgate?
6) What type is used in the imported tailgate?
I'm looking for OEM quality and strength and anything that is imported is a big red flag to me because it's usually low quality junk that is inferior to OEM stuff! However, there may be some good quality imported stuff, but I'm sure it's from a select source. But I'd rather buy Made in the USA OEM quality if I can find it. Can anyone answer my 6 questions and give some advice about this....from your experience? Thanks...
Dennis Carpenter has an import version but they also have a Ford spec tailgate that is OEM quality. It is also stamped from galvanized steel to help stop rustout internally.
Tailgate - Styleside | Dennis Carpenter Ford Restoration Parts
I would avoid the import tailgates like the plague. I've never used one but I know a couple of guys who did. Both regretted it. One sat on his tailgate and bowed it, the other could never get it to fit correctly. It tended to open while going down the road.
They are licensed by Ford to reproduce them and are built to OEM specs. The fact that they're made using double sided galvanized steel is a big plus. And another big plus (to me anyway) is they're made in the USA.
I don't know anyone who has used it but DC has a really good reputation overall and I wouldn't hesitate to get one if I was in need.
I looked on their website and they only seem to have the tailgate with the raised letters. The one I have does not have the raised letters, but rather the tailgate finish panel with the "FORD" embossed on the finish panel. Was the tailgate with the raised letters an option depending on trim package? What designated one truck gets the tailgate with the raised letters and another truck gets a tailgate without the raised letters, but rather the finish panel?
That's exactly what I needed to know. Thanks a bunch for that info!!!
If your tailgate is plain with no Ford embossed on it, then you have an aftermarket tailgate .
I have a DC ford licensed OE tooling tailgate and I truly can't tell the difference from the original ones I've had. Opens and closes great and fits perfect. The body shop didn't complain one bit about it (the same cannot be said about the drivers side bedside (non-OE tooling)....I do need to lower the right bracket a bit though.
I've seen on the websites I mentioned in my original post that they offer both tailgates with raised letters and without raised letters. What doesn't make sense to me is why would Ford install the finish panel over the top of the raised letters? What's the purpose of doing that?
Making the die for the FORD doesn't cost that much more than a plain panel. In the quantities Ford deals with, the cost is probably a couple of cents a tailgate, so it's not worth it to Ford to make two different panels.
The finish panel, there were a couple of different versions, were used on the Ranger, Ranger XLT and Lariat trim levels. The Custom and Explorer got the tailgate with no trim.
Also, there will be a substantial price difference between with and without the Ford stamping.
Welcome to mass production. It is much cheaper for Ford to make one panel than two. They only have one part number to manufacture, market and stock.
