Sorry, another wheel question
Old 08-24-2016, 03:13 PM
Dakster's Avatar
Dakster
Dakster is offline
I like the look of your truck dawn patrol. Although in those can't stick out past the fenders states, you wouldn't pass... Again, not that I care. In rain, snow, slush and nastiness you are the one that gets it worse than you dish it out. (I know from experience). Looks like you live in a non-snow area though!
Radium - It is what it is and your truck works for you the way you need it to and that is great. It's all I can ask of mine. I can't go up an inch in mine or it won't fit in the garage. I have to be careful about snow/ice build up too. Debating how I am going to do that, since my 8' garage door only opens up about 7'. This is the first winter at my new place.
smoky diesel - that looks tough too! Like it as well.
Old 08-24-2016, 06:12 PM
Rubiconrod's Avatar
Rubiconrod
Rubiconrod is offline
Originally Posted by smoky_diesel
OP, You will find that there are not many choices of offset/backspace. For a given style/diameter, there many be only 1 or 2 choices. For a given width, there may be only one... Yes you can order custom wheels (likely forged, and $1000 each)
That being said, with factory flares, you have about 4.5" from hub face to the fender.
So for a 9" wide wheel, an offset of 0 (backspace of 5) would be close to flush.
Most 10" wheels have a negative offset (stick out further), and combined with the extra wheel width will hang out about 2"
How do I know this? I measured the stock wheels before I ordered mine, and calculated exactly how far they would stick out past the fender.
Note that backspace conversion from offset includes the inner lip of 1/2". So for 0 offset case, 9" / 2 = 4.5" + 1/2" lip = 5" back space
37x12.50 on 20x9 with 0 offset (aka 5" BS)
Thank You very much for the info. I'm assuming that I can order factory flares online if needed/wanted as well?
Old 08-25-2016, 12:11 PM
smoky_diesel's Avatar
smoky_diesel
smoky_diesel is offline
Your welcome. Yes you should be able to get factory flares, however they don't offer much more width... Post a pic of the wheels you are looking at.
Another note on width. I clear 37s with only 3.5" of lift. I think with a 20x10 -25 offset wheel you would need another 2" of lift. Many run 6" lift for 37s.
Old 08-25-2016, 03:43 PM
Rubiconrod's Avatar
Rubiconrod
I haven't narrowed down a specific wheel yet. All I know is I want non-black. I'm old and old school. I just got a Carli 2.5" leveling kit installed and will most likely go no bigger to 35" tire's since I tow a fifth wheel. I just really dislike the wheels that came on my Lariat.
Old 08-26-2016, 03:45 PM
smoky_diesel
I ran the 295/65-20 (35.4 x 11.8) when I had a 2" lift.
Looking back I may have gone with an 18" wheel instead of 20". Even a 35 has a small sidewall on a 20" wheel, and makes the tire look small. Heck even 37s don't look very big on a 20" rim/superduty.
Old 08-28-2016, 11:17 PM
99 f150's Avatar
99 f150
99 f150 is offline
So if you don't mind me hyjacking the thread instead of starting another...
I was going to do 20x9 or 18x9 with a +18 offset, 5.7 backspacing.. It will push the tire out 1.3 inches, how tall of a tire could I run? The sizes I was thinking was 295 60 20 which is 33.9 or 295 70 18 which is 34.3 Would those clear with no leveling kit? My buddy ran 295 65 20 which is 35.1 on the stock rims and it cleared everywhere but full turn on trailing arm...
Do you think an inch shorter but out an inch would clear mud flap and bumper? Trailing arm I think would clear easily.
Old 09-06-2016, 04:30 PM
Rubiconrod's Avatar
Rubiconrod
Ok so I found an 18x9 wheel that I like. But my only options are a +18 or a -12 offset. Which one of these two will keep the tire as close to flush with the fender like the stock wheels?
Thanks!
Old 09-06-2016, 04:45 PM
radium's Avatar
radium
radium is offline
18+ - numbers move out + numbers move in , and other factors check on line for wheel calculator will give you and idea of back spacing take care
Old 09-06-2016, 04:50 PM
Rubiconrod's Avatar
Rubiconrod
Thanks for the prompt reply. Much appreciated.
Old 10-04-2016, 09:14 PM
chas111's Avatar
chas111
chas111 is offline
I like the grill inset. Where did you source?
Old 10-05-2016, 09:32 AM
dawn patrol's Avatar
dawn patrol
dawn patrol is offline
Trailering
Old 02-01-2020, 01:12 PM
Cory856's Avatar
Cory856
Cory856 is offline
Tires and wheels
I have a 2019 F-250 super duty with factory suspension. I want to put on 20x10 aftermarket wheels with -25 offset with 33/12.50R20 tire. Anyone know if this will work without any rubbing? Thanks
  #28
Old 02-01-2020, 01:37 PM
Overkill2's Avatar
Overkill2
Overkill2 is offline
Making donuts deplorable
Received 6,367 Likes on 4,626 Posts
Check out https://www.customwheeloffset.com/
They have customer's trucks on there with the specs of the new wheels they went with, what they had to do to get them to fit and pics also.
https://www.customwheeloffset.com/wh...Duty&year=2014
Factory wheel offset is +40 mm.
jimalbert
1999 to 2016 Super Duty
09-08-2014 07:10 AM
TractorMaster96
04-03-2013 09:08 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
11-17-2011 10:06 PM
smallblock351w
08-24-2006 08:59 PM
davidsheets
08-03-2006 04:39 PM
Quick Reply: Sorry, another wheel question
