1990 f350 7.3 turbo
those injectors are for gas engines.
your boost numbers look about where that should be on a properly running engine.
boost from a turbo is only made when the engine needs it, not all the time.
driving down the road my trucks only make 1-2 lbs boost, even when towing 10,000 lbs.
but if i put my foot into it i can easily see 15 lbs on the 88 and 30 on the 02 powerstroke.
running empty the 88 will only make around 10 lbs full throttle uphill.
Received 3,102 Likes
on
It's a hypermax. without a properly tuned IP fuel screw and without a properly timed engine, 2-4psi is pretty typical. In fact, that's kinda high.
Also, how sure of your boost gauge are you? what kind of exhaust do you got?
Don't go out buying a set of Aceel fuel injectors when your boost gauge or sensor could be failing. Narrow the variables first, then make purchases. And as for purchases, don't buy those injectors ever.
My fuel pump just went out. So good possibility it has been weak for a while.
@30 gph i am going to upgrade to 80 and change the injectorsto a stage one i found online.
http://www.idiperformance.com/store/c4/Injectors.html
Suggestions then? I live far from the shop . So when i send it i like to have it all.
Im also thinking of changed the compressor
Wheel
http://www.idiperformance.com/store/p78/Wicked_Wheel_2_Compressor_wheel.html
Fuel pumps, imjectors then wheel.
My gauge was tested and turbo, they are correct
on
The test procedure at cranking RPM is that you should get 1/3 pint minimum every 10 seconds at the Schrader Stem with core removed ...
So, lets just do the math. (not my best subject)
<table><tr><td>3600</td><td></td><td>Seconds in an hour</td></tr><tr><td>/</td><td></td><td>Divide by</td></tr><tr><td>10</td><td></td><td>Seconds for each 1/3 pint</td></tr><tr><td>=</td><td></td><td>Equals</td></tr><tr><td>360</td><td></td><td>1/3 pints per hour</td></tr><tr><td>*</td><td></td><td>Multiply by</td></tr><tr><td>0.3</td><td></td><td>1/3 pint</td></tr><tr><td>=</td><td></td><td>Equals</td></tr><tr><td>108</td><td></td><td>Pints per hour</td></tr><tr><td>/</td><td></td><td>Divide by</td></tr><tr><td>8</td><td></td><td>Pints per gallon</td></tr><tr><td>=</td><td></td><td>Equals</td></tr><tr><td>13.5</td><td></td><td>Gallons per hour</td></tr><tr></tr></table>
I'd really like to see the Ford IDI that can drink (and burn ...) 13.5 Gallons Per Hour!
And that's not only rounded down (.3 versus .333...3), it's figured at cranking RPM and through the restriction of the Schrader Stem.
That would be one bad *** IDI or a hella smokey POS!
-Enjoy
fh : )_~
-Enjoy
fh : )_~
on
I'm a bit concerned for the OP. I'm not sure where you are getting your IDI parts info, but you've been off on nearly everything.
Stop trying to hi-perf everything before you get the basics figured out. Fix your engine, then invest in the hi-performance parts once you have the important things (like studs) done first.
Joes1stdiesel
1999 to 2016 Super Duty
09-27-2012 09:58 PM
Ravenous Weasel
02-01-2012 09:35 PM
Fordson1
02-11-2007 08:59 PM
