Oil cooler?
Old 08-19-2016, 02:02 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
Oil cooler?
2005 Super Duty, 6.0, egr delete, 65 mph on flat highway, unladen, coolant temp 178*, oil temp 196*. I have read that with a delete that the temp spread isn't as critical. But I've never seen this much spread before. Am I looking at oil cooler? Thermostat? Getting ready for an RV trip next month! Thanks in advance guys.
Old 08-19-2016, 02:36 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Change the thermostat
Old 08-19-2016, 03:46 PM
navistarnut's Avatar
navistarnut
navistarnut is offline
This engine is a lot happier around 190* and up, and will likely be reflected in your MPG and performance. You are just wasting fuel at those temps.
I will say I have not read that deleted the 15* spread is not an issue, you are still running an OEM cooler and not air cooled but perhaps there is another view point on that.
Old 08-19-2016, 05:34 PM
olfordsnstone
Ok, thanks guys. For the record, after holding at 178* coolant temp for 20 minutes or so, she finally rose to about 190*. The oil temp rose simultaneously and maintained an 18* spread. I'll change the thermostat. Seems to be sticky. Thanks again!
JamesMcMn
10-17-2016 10:47 PM
mntruckguy
06-30-2015 08:21 PM
2000 Ex-cursion
04-30-2015 12:55 PM
LiftedBlackHD
02-07-2015 11:20 AM
strokin83
05-24-2012 05:24 PM
Quick Reply: Oil cooler?
