Help! New 2.5 sticks and new BD turbo
Old 08-21-2016, 01:15 PM
tshrager's Avatar
tshrager
tshrager is offline
Originally Posted by funzjb1
Yes, I have two trucks the one pictured in my signature and a 1997 which is the one giving me the problem. When I did unplug sensor the idle did not changet and I did drive it while unplugged no difference. But it never threw CEL??? When unplugged.
About a 5 min test would be to swap MAP's.
When I did some work years ago, I had the MAP removed. It got late and I forgot to re install. Ran like dog pooh on the way home. Popped the hood the next day, it was staring me in the face. Plugged back in and it ran like a champ.
  #32
Old 08-21-2016, 01:18 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
I will give it a try. The strange thing it just worked fine the day I changed stuff. Is it possible to " blow" one out with new turbo and bigger sticks???
  #33
Old 08-21-2016, 01:22 PM
tshrager's Avatar
tshrager
tshrager is offline
Anything is possible. It could also be that it was about to go and you helped it along. Who knows. Swap it and report back.
Get it running right and start saving for e fuel and a better turbo.
  #34
Old 08-21-2016, 01:24 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
What do you mean better turbo?? It is a new BD 30% bigger
  #35
Old 08-21-2016, 01:25 PM
tshrager's Avatar
tshrager
tshrager is offline
It's never going to flow enough for your injectors.
  #36
Old 08-21-2016, 01:30 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
They told it would, that why I got it??? What makes you say no??? Just curious.
  #37
Old 08-21-2016, 01:37 PM
tshrager's Avatar
tshrager
tshrager is offline
There simply isn't a "drop in" turbo that will flow enough air to balance the amount of fuel you're throwing at it. To make your combo work right, the tuner needs to pull fuel out of it. And at that point, why bother with 2.5's? You will be battling heat and boost.
  #38
Old 08-21-2016, 01:42 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
Wow, $3k wasted sounds like
  #39
Old 08-21-2016, 01:43 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I will check that when I get off work. But wouldn't the map sensor hose failure ( if it did) show up on the pressure test??? It held 30 psi of shop air just fine.
It is possible to damage the MAP sensor with too much boost. Change the MAP sensor and see what it does.
  #40
Old 08-21-2016, 01:51 PM
tshrager's Avatar
tshrager
tshrager is offline
I sure hope that turbo wasn't 3k. But I'm assuming that was injectors and turbo. Not wasted, but some of that money could have gone elsewhere. I'm running stage 2's on stock air. You really have to pay attention to what you're doing. And know your truck. I have upgraded to a B&W S369 with T4 mount. I don't have this in yet, but it's a SIGNIFICANT upgrade in turbo. Plus the t4 mount gives many turbo options down the road.
What Bill said.
  #41
Old 08-21-2016, 02:05 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
Yes, 3k for turbo and injectors. I run stage 2's on my other truck with stock air also. I just wanted to try ltitle bigger with this truck. I was shooting for 500 hp
  #42
Old 08-21-2016, 02:14 PM
tshrager's Avatar
tshrager
tshrager is offline
Not with That turbo. You need more air. Not to mention e fuel. You have head studs, push rods and valve springs?
  #43
Old 08-21-2016, 02:33 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
I am planning on it. I just wanted to some now, some later
  #44
Old 08-21-2016, 03:03 PM
fordman67's Avatar
fordman67
fordman67 is offline
Man stuff.
Bd has nothing I will ever need
  #45
Old 08-21-2016, 03:11 PM
funzjb1's Avatar
funzjb1
funzjb1 is offline
Very nice!!
Quick Reply: Help! New 2.5 sticks and new BD turbo
