Dying and hard starts
dying and hard starts
X2 on the wiz filter. They also make one wix 33805 that has the sensor port for water in fuel. Both of these have the built in drain. They are not like the old 6.9 filters.
Received 3,101 Likes
on
Didn't mean to leave y'all hangin for as long as I did. I did pivot bushings, services/replaced bearings, and also working on the subby.
So, I'm sure I'm getting air in my fuel lines, not sure where yet because it's maintaining neutral pressure but will suck air under negative pressure so I'm thinking kink the line near the tank and supply positive behind the lift pump to locate the leak.
I think I also find the oil leak. It's either the return or pressure line to the turbo. Lots of oil
It's the one that goes into the top of the block behind the valley. Looks like about where the top of the rear main would be. I'm thinking easy fix.
Is this common? I tried to get pictures of it but phone needs to lose weight.
The picture added is how much fuel pumped in ten seconds of cranking. It did try to start during this test.
The mark is where 2/3 of one cup would be so that should equal 1/3 of one pint.
I did change the filter to a solid one, no leaks as of yet. But I'm still unsure of what that little hose is. Looks like it's a vacuum line but I'm unsure. It looks wet in the picture only because I bled the line to see if it was still frothy or if there was positive air pressure in the filter. There was.
Thank y'all!!!
on
the push on connector is the water in fuel wire. mine has been disconnected since 1990.
the line is the drain tube so when you drain the water separator the drained liquid went down under the engine instead of all over it. that has also been disconnected since 1990 on mine, i have never drained the filter.
justaworktruck
26
07-14-2016 04:13 AM
carolinaranger90
03-09-2011 05:05 AM
clackmaster
06-24-2010 10:52 PM
