Thinking of getting a Ranger, what to look for?
Old 08-17-2016, 12:43 AM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
Hey all. My dad has been talking about wanting a little pickup for Home Depot runs, chores, etc. I'm going to surprise him and buy one for him. I'm looking to keep it at around $4000. The only thing I've heard him mention is that he wants an extended cab. I'm looking at '90's-early '00's with my price limit. So, what things should I look out for? I'm in Southern California, so rust isn't an issue, my main concerns will be mechanical. I'm finding trucks with between 150-225k. Any weak spots to really check while looking at these? Thanks for any help and advice
Old 08-17-2016, 12:42 PM
02FX4Dude's Avatar
02FX4Dude
02FX4Dude is offline
Speaking from my 2002:
Check rear spring shackles, they're know to be weak and collapse but that's usually a rust/corrosion thing.
4.0 SOHC up to 2002 (2003 depending who you talk to) had timing chain tensioner problems.
2002 FX4 Torsen rear diff know to grenade.
If auto transmission, the 5R55E had some TSB's to cover delayed shifting and RPM flaring, there's an epic mega-thread discussing that.
Old 08-17-2016, 12:50 PM
spooktn's Avatar
spooktn
spooktn is offline
Temporarily Deactivated
My main concern would be how well maintained the truck was,,,oil changes and such,,and parts like sensors and filters. The mid and late 90's 3.0L had a problem with the Camshaft scyhronizer not oiling properly,,, they are not that expensive and not to hard to replace... The bushing not getting oiled well would cause the part to fail after so many miles.. Depending on the miles and how well maintained you can bet on replacing a few filters,, sensors and other odd and ends. I have a 99 with the 3.0L with the extended cab and love the extra room it gives a great place for jumper cables and what have you to be stored.. Good gas mileage and after some needed maintence it is very dependable so far.The 3.0L is not a speed demon but gets the job done,,, never had a 4.0L but supposed to have a few more horses.. Hope that answers a few of your questions
Old 08-17-2016, 12:55 PM
46fordtruck
All of this helps. I think I'm going to focus on '98 and newer. I've been finding a lot of extended cabs, most with manual trannys, which is okay. One question, regarding engines, did an extended cab get a V6, or was the 4 also in them? I'd rather get a V6 than the 4. While it will be for his use, I'll also be using it now and then. Did the extended cab ever have a rear door that opened?
Old 08-17-2016, 02:01 PM
spooktn's Avatar
spooktn
spooktn is offline
I have never saw a extended cab 4 banger,,, not sure if they ever built one that way,,, as far as the 3 rd door goes yes they have then but not sure in what year or years they were made,, a couple of pic's here if I can copy and paste them.....
Old 08-18-2016, 05:52 PM
46fordtruck
Seems the extended cab with the door is mixed, some have, some don't, and I've seen the mix on all the years. Maybe it's an option? Can't say I know a whole lot about the Rangers, F150 yes, Ranger no.
Old 08-19-2016, 03:29 PM
46fordtruck
How close are the Mazdas? Is it basically just different sheetmetal with the same running gear?
Old 08-19-2016, 05:33 PM
spooktn's Avatar
spooktn
spooktn is offline
They are the same truck just badged different,,, they have same frame doors engines and well everything is same except the name,,, same with Ford Mustang and Mercury Carpi ,I could pull my 1985 Carpi beside a Mustang and hide the badge and you could not tell them apart,,, again same everything but name !
Conanski's Avatar
Conanski
Conanski is offline
The Mazda B3000/4000 is the exact same truck with a slightly different front clip.
Old 08-23-2016, 01:01 PM
WXboy's Avatar
WXboy
WXboy is offline
If four wheel drive, look for a later model. The 99-01 (?) had the vacuum hubs and they were junk. I think '02+ went to the Explorer setup where the front shafts were connected permanently and those are great.
Old 08-23-2016, 05:26 PM
fletchb's Avatar
fletchb
fletchb is offline
I don't know about the year range you are looking at but I can tell you I ended going with a Reg cab, in part because I could not find an extended cab with a 6. All the clean-later model Rangers ('10+'11) I looked at had 4 cylinder engines and I was worried the extra weight might be a bit taxing. I should have test drove one as my '11 I4 Reg cab turned out to be a lot quicker truck than I expected, but that is what I found when I was shopping a few months back.
Good luck.
Old 08-24-2016, 12:07 AM
46fordtruck
Good luck.
Looking at '98 and up. My budget is going to be around $4500. The extended cab will be for the little extra storage space. Most trips he uses it for will have my mom with him, so some space behind the seats will be for groceries, cargo, etc. And going with 4 wheel looks like the 6 is the only option.
Old 08-28-2016, 12:51 PM
NDL's Avatar
NDL
NDL is offline
I don't know of many problems with the Ranger (thus the lack of problems posted on this thread).
The 5 speed manual gearbox is a Mazda transmission. At the top of the gearbox, are three rubber plugs that shrink and crack over time, which leads to a lack of oil in the gearbox.
The rubber plugs aren't expensive to replace, nor are does the job require any serious skill, time, or effort.
That's the only thing I can think of...
I have a 2.5L powered 2001 Ranger, with 190k. Knock on wood, it is all original, save the rear differential, battery, and tires. Uses 1.5 quarts between oil changes (every 3.5k).
The 2.3L engine has a timing chain that requires no maintenance; the 2.5L has a belt. The tensioner spring can sometimes go; mine went at 80k, and I am told it sometimes happens.
Love this truck. Only complaint is that I wish it had more legroom...
Old 08-31-2016, 04:42 PM
fletchb's Avatar
fletchb
fletchb is offline
If you go with the older one's I am sure a 6 will not be hard to get. And even so, a 4 might be fine, just test drive one and make sure if you go that route.
Old 09-05-2016, 11:00 AM
98 Thunderbolt's Avatar
98 Thunderbolt
98 Thunderbolt is offline
Post >>>>
I had a 87 Supercab with 2.3L. 2.5L Lima motors had quite a few issues, I've had 98 & 2000 with 3.0L's with no issues.
4 dr. Supercabs weren't available till 99 or 00, as I had a 98 that didn't have back doors.
83-97 are a twin I beam type setup, 98up non-Edge 2 wd are upper & lower control arms, 2wd Edge & all 4x4's are torsion bar setups.
Hope this helps ya out with your purchase.
Quick Reply: Thinking of getting a Ranger, what to look for?
