Exhaust manifolds 100° difference
Has anyone ran into this issue on their FE? My passenger runs about 470° at idle operating temperature and driver side runs around 350°, from what my grandfather says is its possibly a "partially" internally collapsed manifold, he's ran into that issue before. So am I looking at another excuse for headers or another issue? All exhaust port temperatures are similar to the manifold temperature.
Note that no matter where I measured the temperature it was always a 100° difference (give or take 15°)
Collapsed manifold? I've got a bridge to sell him...... what about a raccoon?
Have you checked for lean on one side? Like an intake manifold gasket sucking wind?
Do a vacuum check and compare plugs from right to left bank.
Manifolds do not collapse. Gaskets do, and mixtures from right to left change temperatures.
Another cheap diagnostic would be to have a smog shop compare hydrocarbons on each bank, if you have dual exhausts. And access to a smog shop.
Just to be clear, while it is true that the two barrels of the carb only service 4 cylinders each, they cross in the intake (dual plane) so each barrel services two cylinders on each side. I don't think adjusting the lean/rich of the idle mixture screws will change your heat issue. If you do have the flapper valve after one of the exhaust manifolds I would test it to see that it does in fact move freely.
My carb was boiling over and pressure was really building up in the line, noticed no ( forget the term but the exhaust circulating in intake to heat the carb/fuel) so led me to think of a restriction in the exhaust/manifold
On the different temp exhaust manifold, my 1st reaction was plugged,smashed, or kinked R/S exhaust pipe or muffler if you have duals. Did you run over something in the road recently?
The flapper isn't exactly part of the manifold, it's sandwiched between the manifold and header pipe.
