Power window Kits?
Received 4,131 Likes
on
The horizontal bar is bolted to the door using long enough bolts and spacers( I used tubing) to line up with the window track and it supports the motor and the bottom of the power window track, I've been looking to see if I have any pictures but haven't found any yet...
This instruction sheet from Mid Fifty makes it pretty clear.
Instructions - Mid Fifty F-100 Parts
I can't tell from the pictures if the the tubing is 1" or 3/4"
on
I'm starting my install and have questions. I have 2 different instructions and one says put the motor on the hinge side the other says put it on the latch side. I like it better on the hinge side, does it make a difference?
I followed the dimensions for the locating the unit in the door. It centers it in the panel opening/door. It seems to be slightly off center. Should the vertical bar be perfectly in the center glass? (I am keeping the vent windows)
One piece windows
Finished the instl. of my Nu-relics one piece electric windows in my 52.
Motor unit was a bolt in deal in the original holes.
Forming the felts was a bitch until I carried them down with one window to an old time glass company which did them in about 45 minutes!
I trashed several trying myself but I was keeping my hands too close trying to bend them. This guy worked about a foot or more apart with his hands and wider.
They went in like a dream, I cut them off to the correct lengths and the window roll up and down like a dream.
TractormanBill
TractormanBill
I got the driver side done. It works great. The hardest part was determining the correct spacers to use. Once I got that the unit fit in the door perfectly. Now the other side should be a lot quicker. I need new glass so I will get that before I take it apart so I can do it all at once.
on
I like using these looms because they are less likely to bind because of the pivots and slide much easier
https://www.electric-life.com/produc...ip-on-collars/
I used these looms for the wires.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I originally drilled the holes in the center of the door jamb but the bend was too tight. I used the hole for the dome light switch which is very close to the inner edge of the jamb and it worked much better.
Mine is a 56 and the door angle is different than the 52 like tractormanbill showed
#28
#29
I had the ones Smallello used and I did not like the crimp in the tubing when door was wide open. I like the design of the electric life product you used so I ordered them.
I actually looked into a hyme joint to see if I could make the ones I have work but it would have been totally to big.
On a side note if anyone on here needs a power window kit, bought from Mid-Fifties with install kit, never been used. I bought the Nu-Relics. It is yours for the cost of shipping.
Page 96 Mid-Fifties 2015 catalog-part #1740-ex
MERRY x-MAS to all
