2010 Mountaineer V8 AWD
For now I'd suggest you consider the noise at low speed as possibly an independent issue from the whine at higher speed. It's possible the noise at low speed has you more sensitive to other noises that maybe have been there awhile.
When you mention you only hear the noise when under load, what type of load are you referring to? Going up hill, hauling things, accelerating lightly, etc.?
Does the noise immediately go away if you let off the accelerator or apply the brakes?
Have you checked the fluid level of the transfer case and front differential?
Does the noise change if you go around a turn while still accelerating or doing whatever it requires to load the system?
If you happen to know someone with a Steelman ChassisEar, that will help you pinpoint the source of the noise.
-Rod
-Rod
FordFanFrits
1999 to 2016 Super Duty
02-24-2012 09:38 PM
afonda
19
12-11-2008 09:08 AM
Graygeorge
09-28-2008 10:39 PM
sebas54
11-10-2005 02:47 PM
