Where can i buy a complete drop in 7.3L?
Hey guys i was hit by a dump truck last week and my daily driven IDIT was totalled, i am looking at using my 1996 powerstroke for now and would like to drop a new crate motor in it. It has 280k, it runs great but i found the source of the exhaust leak is a broken exhaust bolt in the head, it also looks like there might be a leak from the oil cooler tube, i just pressure washed everything clean. Anyway, i don't really have the extra time to pull an engine, drill bolts out, assemble a long block etc, i'd rather just get one ready to drop in and swap it out one weekend.
Who is a reputable builder that i could get one from with a warranty?
Also, can i support the transmission in this truck and pull the motor without pulling the transfercase and transmission?
Drilling that bolt out and removing the oil cooler to R&R will take you a couple of hours with the motor in the truck. It is straight forward and easy. Much cheaper than a rebuild! Locally for a rebuild kit, machining, and assembly of the short block is around 2800-3300 if there are no major issues, headwork is another 5-800. This is all using a core motor. You can likely still sell the block for 1k+ even with that mileage.
Swamps, pull out your checkbook or go find a runner on CL
Yes you can unbolt the trans and torque converter and pull her straight out. On a manual its even easier.
Thanks!
I actually have a studded 7.3L IDIT sitting at a machine shop now that was waiting to go in my daily IDI i really just didnt feel like have to assemble another motor after everything that's happened. The engine also has a rusty oil pan. It doesnt seem to be leaking, but the dip stick part which i am sure i can get to seal with RTV. It was one of those things where i'll probable be 10+ hours into fixing and repairing all that and i could just drop a new engine in.
If i keep the engine in i plan on removing both manifolds and up pipes since the manifolds look like they are near their service life, if the turbo is coming off then id replace it anyway with whatever upgraded one you guys would recommend. I just spent a good bit on a BW S257X for my IDIT that wont go on it. I do have a water/AIR intercooler i plan on swapping over from my truck when i buy it back.
I ended up ordering just the driver side manifold, some stainless bolts, a gasket, and a new oil cooler tube and o-rings. I dont need to actually remove the up pipe to replace the manifold do i?
I also ordered this interesting set of guides and bits, i have some left handed drill bits somewhere but i am going to try to weld a nut to any broken studs. I did order a stud extractor too. I plan on cutting all of the bolts and extracting that way, is that the preffered method? Or can i just demolish the manifold with an air chisel since i have a new one? i plan on using nickel neverseize on all the new hardware and using a thread chaser for all of the holes
http://www.ebay.com/itm/261659054019?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The bolts on the up pipes are just about gone on both sides I figure I'll have to drill then out on the driver side. Thinking about it all none of the up pipes or passenger side manifold are leaking so I'm not going to touch them until they start to.
I pressure washed everything real good a week ago, then pre soaked twice with Kroil, then pressure washed up real close on every bolt head and thread I could get as close as possible, let it dry, then soaked them in pb, then I'll keep spraying everything down in Kroil each day before I get to it. I'm spraying all the bolts even the turbo just incase something happens and I gotta try to take them off too.
The two bolts for the up pipe are 5/16 I believe I may get them from the local hardware store in grade 8 or stainless.
I removed the ebp line, bracket and sensor today and found it all completely clogged. Got sensor cleaned but ordered another, have esco making a new hard line and I welded a new fitting in the bracket since I wasn't happy how dirty it was after cleaning
I ordered these for the up pipes
https://www.amazon.com/gp/aw/d/B015P...?ie=UTF8&psc=1
I ended up buying a new ebps tube and the connection fitting. Mine was all clogged too.
http://www.ebay.com/itm/like/131261599742?lpid=82&chn=ps&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D53601919689_324272%2526itemid%253D131261599742%2526targetid%253D173539366329%2526rpc%253D0.28%2526rpc_upld_id%253D74877%2526device%253Dm%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fulk%25252Fitm%25252Flike%25252F131261599742%25253Flpid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526googleloc%253D1018248%2526poi%253D%2526campaignid%253D239125209%2526adgroupid%253D14978428809%2526rlsatarget%253Dpla-173539366329%2526gclid%253DCOyw56TlxM4CFUUmhgodeW8Ebw%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1077708585946&ul_noapp=true
Those are the exact ones I ordered. Seemed like a good deal. I plan on brass wire wheeling head then painting all surfaces with nickel never seize. I've had good luck with doing that on slip joints, flange surfaces, hubs, u joints, and socket connections. it seems to keep the metal from rust/pitting by keeping moisture off of the metal surface.
mcali2
16
06-15-2017 09:37 AM
jomoflymo
12-30-2014 03:52 PM
bashby
12-05-2014 08:21 AM
jclark4cs
02-06-2006 11:17 PM
