E40D Shift Issue
Old 08-22-2016, 06:35 PM
krifenbu's Avatar
krifenbu
krifenbu is offline
Originally Posted by Raleigh234
I solved the problem!
Earlier I said I replaced the Range Sensor, which was a mistake. I meant to say I *bought* one. Today, I got under the truck to actually replace it, and the range sensor was extremely loose (I could twist the bolts with my fingers). The shifter cable was also rubbing against part of the frame, because the sensor itself wasn't seated correctly. After replacing everything and tightened it all down, I noticed several problems were fixed:
- My shifter in the steering column is significantly more stiff
- Truck starts in park (finally)
- Shift points were much more firm
- Erratic shifting has disappeared
- Mystery squeal that I assumed to be a bad wheel bearing disappeared (it was the cable against the frame)
Good job and thanks for posting the fix for the rest of us to learn by.
ebaldwin89
17
02-27-2018 12:22 PM
JustinAK5
1999 to 2016 Super Duty
03-26-2015 06:55 PM
ace33172
06-12-2011 08:05 AM
That_Guy
23
03-22-2008 02:30 PM
trsest1
04-01-2004 10:23 PM
Quick Reply: E40D Shift Issue
