Change Oil Soon Warning
2013 Ford F-350, CC. Lariat.
This may be very simple, but this morning I recieved "Change Oil Soon" warning. I had the oil changed at about 20,500. Current odometer is about 22,530. I am thinking that when the oil was changed the garage did not reset the oil life in the message center.
Just looking for some info to back up that thought, or if there may be somehing else going on that I may need to look at. Have not had a chance to get into the Owners manual as this happened 30 minutes ago on the way to work.
Thanks.
Eric
Thanks.
Eric
Yup, that's quite common, lots of shops aren't yet in the habit of resetting those.
The Oil Life Monitor doesn't actually analyze your engine oil, so it must be reset every time the oil is changed. So if they didn't reset it, the computer thinks the oil is the same from when it was last reset. It's virtually impossible to set off the OLM after 2,500 miles, so I think you're safe to go to your next regularly scheduled oil change. You can always reset it yourself to get rid of that message.
shark1979
6.7L Power Stroke Diesel
12-30-2013 11:44 AM
