Wheels for my 56 with Crown vic front end
I found some wheels that at 18x7 with 0 offset and 4" backspacing. I took measures for my rear with the explorer differential and they will fit the back. The fronts I'm not too sure on. I don't want to push the wheels out too far on an already wide front end. The crown vic wheels fit the front pretty well with the fenders. But I know they have a high offset.
Thanks in advance
Thanks in advance
Do you have photos of your cv front end at the frame rail? I'm thinking about removing my lower block so the frame sits lower and then flattening the frame rail. Then ill put a block on top for take up the spacing.
I was figuring I would need a pretty decent sized offset for the front. 35-50mm offset is like 1.5-2" so I don't think the rims I'm looking at will work.
I may have to toss a fender on there to see where it is at.
on
OEWheels-Tech
26
02-09-2017 09:12 AM
fordf350camper
03-19-2010 05:24 PM
