223 6 exhaust routing?
Can anyone with a 223 6 cylinder share a picture of their exhaust routing?
I ended up getting a pre-bent kit from LMC. I believe it should go:
- piece 1 - down from manifold, under oil pan
- piece 2 - under oil pan, and over front suspension
- piece 3 - muffler under passenger cab
- piece 4 - straight back toward rear
- piece 5 - over rear axle
But for the life of me, I couldn't find a clear way over the rear end.
I finally hooked up the straight piece to the muffler and ended it right there, just ahead of the rear wheel.
Maybe sufficient, but maybe someone can show me what I'm missing?
So, you seem to be almost there. Let's start up front: From the manifold, the exhaust drops down and runs on the passenger side of the block - and doesn't cross under the pan. The pipes hug the inside of the passenger frame rail from front to back. You have the muffler correctly placed under the cab. The pipes cross above the differential before terminating behind the rear wheel.
Pics:
Pics:
Here are a few shots of the Panel truck. This exhaust is rusted through many places and hangin on by a thread, but it's there!
It is too bright outside to get good photos, these are absolutely terrible. Either wait for someone else to reply, or I'll get better ones this evening or tomorrow. Got a BBQ to go to I think.
Nigma
07-11-2016 10:40 AM
strokin'_tatsch
15
05-01-2011 09:24 AM
