Retail Orders: Check In Here
#962
Don't hold your breath ....... you'll lose. We ordered out our '17 F250 XLT SuperCab 4x4 longbed gasser with a 4.3 rear end in mid-JUL, gotta VIN Halloween & was built 17 NOV. It's @ the dealer as of today, 5 DEC but still gotta get splash guards installed, spray-in bedliner, & Bakflip tonneau cover. Hope'n to bring'r home on FRI, 9 DEC.
Here's what it looked like sit'n on the transport this AM.
#963
The date in the bottom center is the date the sticker was printed. Mine showed up with an 11/24 date, then reprinted to 12/01, then truck was built on 12/04.
If built, your truck should show up with a build date when you search under vehicles here: FordEtis home page
The date is in DD.MM.YYYY format. If the date is 11.30.0000 or something like that, it has not been built yet.
Good luck!
#965
Mine took about 8 weeks to get the VIN, and now looking at a 1/1 ETA. All in just about 18 weeks (if all goes as planned her on out). That's about right on based on a post I read a day or so ago that mentioned the weeks to delivery.
#968
It's Built?
ETIS just populated with a build date this morning.
Build Date:
17.01.2017
Vehicle Line:
F-Series Super Duty
Engine:
6.7L 4V V8 T/C Diesel
Transmission:
6 Speed Auto Trans (6R140)
F350 Platinum Ultimate - White Platinum. Looks like I have a shot at February 12 delivery per Ford Chat.
Ordered Dec 2nd Priority 10.
Build Date:
17.01.2017
Vehicle Line:
F-Series Super Duty
Engine:
Transmission:
#970
#971
KYLONGRIFLE the regular cotus never worked for me either. But the site wwwqa.cotus.ford.com works sometime. It works randomly, some days I have to try several times during the day to get it to work, but at some time in the day it will work. Seems to work better in the evening. I just tried to use it and it didn't work but it worked last night. If you are as persistent as I am you will get your answer. In the top left corner it will give you a delivery date. Then in the middle it will give you a status bar. Good luck remember persistence is the answer. Also I used the vin# not the dealer and order# not to say they won't I just always the vin.
Last edited by 17STROKES; 01-20-2017 at 07:32 AM. Reason: Also i was using the vin# not the dealer and order #
jim01250
2017+ Super Duty
57
05-06-2017 07:07 AM
