Ground wire upgrade
Good idea, the auto manufacturers treat copper as a precious metal, the cables are adequate when new but just barely, with the road grime and salt brine and atmospheric pollution, it doesn't take that long to cause trouble. Neglected grounds and connections cause LOTS of problems. They even used dissimilar metals in the past in some battery cables and between ground connections. Better cables, better connections better routing, means longer lived alternators and voltage regulators, and batteries.
Our OBS and Brick Nose PU trucks do not use the so called braided ground strap (cable or wire) for the electrical system.
I decided to try this kit out, kind of pricey, but sounds like quality parts.
https://ceautoelectricsupply.com/pro...ost-batteries/
JayBourbon
12-29-2017 10:23 AM
Nathan Kiolbassa
04-29-2016 02:49 PM
