97 7.3 no start
97 7.3 no start
So a few weeks ago I had a problem with my truck on the freeway when It died as I was cruising and wouldn't start back up for a week. I found out that it was the #8 fuse that blew and it kept blowing. I replaced the fuse, took out the fuel bowl heater and swapped the horn relay and the idm relay to see if that worked. The truck started back up and would stay running for about 3 weeks.
Well last week I took the truck to work and it sat for my whole shift. When I tried leaving work, the truck wouldn't start. So I replaced the fuse that kept blowing and it started and ran fine. Now today, I was leaving for work and went to start the truck. I cranked it and it almost caught but then no start again. I could tell it blew the fuse when it almost started. I don't know what to look for anymore and I need help with this one.
You didn't screw yourself. You narrowed down that you've got a loose terminal connection or break in a wire, at/near the IDM and/or the fuse box. Even if you had it running, given how easy it was to get it to stall playing with the wires, you can bet it would have stalled the next time you hit a good bump; then you would have had a no-start away from home.
I've narrowed it down to 3 possible wires. When I was playing with wires, I was just moving the loose relay box around which moved the fuse box wires. I'll show you the area I'm working with.
I have no idea what the black wire is. And yes, the egt wire is all kinds of messed up. The previous owner did random mods the the truck and put gauges in himself and kind of just made it work without knowing how to do it.
There was a wire running from the kill switch to that fuse but I took it off the fuse but it's still in the truck.
