Help finding Camshaft Position Sensor on 1996 2.3L.
Hey everyone, my check engine light came on about a week ago and was unsure what the problem was. So I tested the codes and it said that the camshaft position sensor was bad. So I have tried finding this sensor but little to no luck. I was unsure if it was the 2 or 3 pin, but after looking at some pictures of the engine I'm thinking it is a 2 pin. I attached two pictures of what I think might be the sensor? But I am unsure. This was right next to the timing belt cover, which is where it said it was located.
Just for everyone to know, I have a 1996 Ford Ranger, 2.3L.
Hope to get some help!
It sure is funny how you cannot 'place' yourself in the context of a picture.
They sure are pics of injector(s) with the schrader valve on the fuel right there for all to see. I had my self oriented to be on the drivers side near the front of the engine, looking down, and could not 'see' the size of the line the injector appears plugged into, so assumed it was a HVAC compressor line, which should be right about there. Not.
That was enlightening. Need 'context' at times to be able to distinguish, and at second look after Conanski comment, bang. He's right on.
The cam sensor should be forward and down from the end of the fuel rail, under everything else...
Need help with diagnostic and repair tips for a Camshaft Position Sensor Error 2000 Ford Ranger 2.5L
VvBOOMvV
1983 - 2012 Ranger & B-Series
13
05-09-2016 08:31 AM
big catfish
01-31-2006 02:43 PM
Tom in TN
08-19-2005 03:50 PM
