Low compression in one cylinder :(
My '88 pickup with the 351w seems to have developed an issue with compression in cylinder #5. The others have about 130 cold and the motor runs awesome except it shakes a little due to the unbalanced cylinder. I'm wondering if its worth putting new rings in and maybe putting a mild cam in it while its out. It has 145k on it. Just looking for opinions on whether its worth it or should I get a used block. Thanks
Thanks guys for the quick replies! The test I did was cold and dry so I assume the other cylinders are pretty golden at 130psi straight across the board. #5 was at 50psi so I am going to try a wet test and then airing up the cylinder. The problem is that the spark plug in #5 gets soaking wet with oil almost instantly after start-up so I am leaning towards the rings but we'll see and I will report back!
TruckerATK
10-04-2016 04:31 PM
bkuuz1
05-04-2015 08:45 PM
PowerstrokeJunkie
43
04-30-2008 04:50 AM
