Ultimate Automotive Leak Detector
Just wanted to Introduce myself and my product. And I hope this is an acceptable location for this guess I will find out soon.
This is a tool made by me and used for leak detection in the automobile through out its every system. It uses*Mineral*Oil*to make smoke. Stick it in*exhaust*it will locate every*exhaust*leak and go on to mark any*exhaust*manifold or gasket leaks it will continue through the intake and*exhaust*valves into the intake manifold to locate leaks in the manifold or its gaskets. You can cover the carb or venture with saran wrap and see any leaks in the*mounting*gasket*for the carb or venture. It can be inserted in the*radiator*and it will locate any leaks in the cooling system all the way from the*radiator*through all the hoses the*water*pump*the*heater*core*the thermostat*housing*the*water*pump*mounting*gasket. You can insert it in the*power*steering*and locate any leaks in the pump or lines also with a special dye it can locate the smallest of leaks Auto Pro Dye from O'rileys Auto parts. Also air conditioning leaks. Oil leaks put the output smoke in the oil fill tube and you will be able to locate leaks in the valve covers the oil pan. The dye is mixed with a 16 ounce container of*mineral oil that is a petroleum product*and then it will travel through the smoke and mark the leak location with the dye and then you just need to use an ultraviolet lite to locate the die leaks. You can locate leaks in the transmission*the rear end and axle seals. This tool will also work on any sealed unit don't even have to be in an automobile. This tool will test welds for leaks such as aircraft parts as long as you can pressure rise the weld and then use the ultraviolet light. It will show you a good solid weld or a poor leaking weld. This 12 volt smoker is completely rebuild able and its built to last for years it has the best of materials 10 gauge wire*heavy*duty*battery*clamps*could be modified to cigg lighter*adapter*30*amp fuse holder with*15*amp*fuse*heavy *duty *made*of the best parts available. I would also like to ad a 60 day money back Guarantee to this tool. Cost is $175.00 plus shipping and can be done through PayPal. Also a little about the tool it has 6' of output hose to go anywhere you need it has 6' of wire with*battery*clips for easy hook up to the vehicle being worked on. I also put a regulator in line with the incoming air as to reduce it to 3/8 lb so it cant damage anything in the evap system or the vehicai. It is compressor ready but you can use lung power as well. It has a 8” carabiner clip to hook from the hood spring while working on a vehicle. The aluminum container gets quite hot because its aluminum and when it gets hot let it cool down because if you heat it up to much too long it may damage the heating element or the connectors and that might void the warranty.
Vendor Specials, Discounts, Product Announcements & Group Buys
08-28-2016 07:51 PM
08-23-2016 07:21 PM
smashclash
06-30-2010 02:16 PM
