fuel pump woes
Absolutely, if you can find the parts. Sort of looked into this, but I wondered if the rubber parts would be fossilized by now and then there's an issue with modern fuels and ethanol so I never bothered. The integral filter canister type used for the FE fits and works well so went with that.
Mac's has them, part # 48-36081-1 (rebuild kit) and diaphragms 48-16873-1 and 48-35461-1 depending on the pump you have. Check carefully that they fit your application. These are for Carter pumps marked 3528 and a few others. Under 10 bucks.
Or do you mean the FE pump? 48-36024-1 70-72 F100-F350 with 360 or 390 , about 50 bucks.
Make sure the screws on your original pump body are screwed down tight, they will loosen up over time and it will start sucking air.
milotrain
06-02-2010 12:57 AM
sc00ter
05-09-2008 09:34 AM
cdherman
11-06-2003 07:52 PM
cdherman
11-04-2003 10:30 PM
