390 Power Steering Assm.
Old 08-19-2003, 04:45 PM
Gidde Up's Avatar
Gidde Up
Gidde Up is offline
So it has been over two years since I disassembled my motor and I can't for the life of me figure out how to put together the PS assembly. I've got the horse shoe bracket back on the pump, but I can't figure out how it was put together so that I could adjust the slack in the belt. Does anyone have a picture of the assembly so that I can get this back the way it should be?
Thanks in advance.
Old 08-19-2003, 06:57 PM
460 Crew's Avatar
460 Crew
460 Crew is offline
I have a pic of the PS setup on a 69 I know the newer ones are different but It depends on which one you have on there. Nice looking engine what valvecovers are those?
Old 08-19-2003, 09:06 PM
Gidde Up's Avatar
Gidde Up
Gidde Up is offline
Thanks for the compliment. The truck is really to be one heck of a project. The valve covers are FRPP COBRA LeMans which are still in the Ford catalog.
Originally this pump came with brackets in the back ( I believe where I adjusted the tention) and the horse shoe which bolts to the front of the pump. Since this is a FE, I'm pretty sure the rear bracket bolts to the water pump. I was concerned about this old pump turning the 33x12.50's I currently have and I know I will go bigger one day, so I jumped up to a Saginaw pump. I found this site that showed how to do it. But, when trying to assemble it together, I just can't figure it out. I'd appreciate the picture if you have it. Here is a link to the pump I had and the pump I now have. Thanks for you help!
http://meb.bronco.com/techinfo/mods/napa_ps_pump/
Old 08-19-2003, 09:30 PM
DuckRyder's Avatar
DuckRyder
DuckRyder is offline
See if this helps at all:
FE With PS
There are several pictures there, if you back down to the directory "F100" all of the pictures with "360" are engine pictures.
Old 08-19-2003, 09:40 PM
Gidde Up's Avatar
Gidde Up
Gidde Up is offline
Great pics. Looks like a good paint job on the motor too! My ps pump does not have that setup unfortunately.
Old 08-19-2003, 09:58 PM
460 Crew's Avatar
460 Crew
460 Crew is offline
giddie did you get the pics I sent you? If thats not it I might have a pic of my 460 setup and it's the same concept as the 390 deal if your interested.
Old 08-19-2003, 10:11 PM
Gidde Up's Avatar
Gidde Up
Gidde Up is offline
Thanks! Got the pics. That is the pump I had but that isn't the bracket. If the 460 has the same pump, I'd be interested in looking at that.
F-1
04-16-2016 02:19 PM
john jamieson
07-18-2015 12:33 PM
Baatzy
05-03-2015 05:01 PM
Cornerman
Offroad & 4x4
11-30-2005 04:07 PM
1991fseries
01-10-2005 05:29 PM
Quick Reply: 390 Power Steering Assm.
