79 ford f150 timing chain guides
Old 08-08-2016, 05:11 PM
brandan123's Avatar
brandan123
brandan123 is offline
Hi i need help to find out if i can just order timing chain guides or if i have to buy a kit? And if i can just get the guides should i order them or go to the dealership? The motor is a 351 modified.
Old 08-08-2016, 07:09 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
351M engines don't have timing chain guides. It's just the chain, cam gear, crank gear and fuel pump eccentric.
In the picture, this engine doesn't have the eccentric.
Old 08-08-2016, 07:13 PM
brandan123's Avatar
brandan123
Ok thanks because the whole reason i started looking is that me and my dad changed the oil and found plastic in it and then we took the oil filter off and there was plastic all over it. Would you have any clue what it would be from ?
Old 08-08-2016, 07:17 PM
brandan123's Avatar
brandan123
Ok nvm my dad found out and thanks for the help
Old 08-08-2016, 07:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, the cam gear.
The OEM cam gear has nylon teeth that will start to disintegrate, that's probably what you're seeing.
Make sure the replacement gear is cast iron.
OEM gears start out like the first pic, end up like the second pic.
Old 08-08-2016, 07:32 PM
brandan123's Avatar
brandan123
Ok thanks so much and yes the ones we bought the other day are all cast iron and now we have to Tear the motor apart to get all the plastic out
Chadloe99
1978 - 1996 Big Bronco
07-01-2013 10:21 AM
dfboothe
1999 to 2016 Super Duty
06-23-2010 10:50 PM
cies_69truck
08-03-2004 11:10 AM
pacochico13
03-05-2003 04:48 AM
woodyropes
06-06-2002 09:14 PM
Quick Reply: 79 ford f150 timing chain guides
