rattle
Old 08-08-2016, 01:54 PM
Richwon4's Avatar
Richwon4
Richwon4 is offline
rattle
When my RPM's get up there I get a rattle going on from underneath. Not sure what that is. Rattle/Vibration becoming more pronounced. Thanks guys I am sure you know what it is.
Old 08-08-2016, 03:12 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Well without you having your signature filled out to let us know what engine you have............
I'll guess that if its a V-10 or 5.4 that it could be the torque convertor cover on the bottom of the bell housing or a loose heat shield on the exhaust around the Y (T) pipe. Those are the two most common RPM related rattles on the gas rigs.
For a loose heat shield you could either remove it or wrap it with a hose clamp to rescuer it to stop the rattle. For the TC cover, remove it and give it a slight twist, then reinstall.
Old 08-13-2016, 05:48 AM
afmedic's Avatar
afmedic
afmedic is offline
If you suspect the heat shield you can get underneath and tap on the exhaust in different points with either your hand or softly with a rubber mallet. If you hear the rattle, have a buddy hold the different heat shields until the rattle goes away and clamp that one. I had 2 that were rattling but they aren't any more thanks to some 50 cent hose clamps!
Boondoggle
08-27-2017 05:51 PM
soupy1957
2009 - 2014 F150
06-21-2015 07:21 PM
RAGaz
Modular V10 (6.8l)
01-25-2011 06:33 PM
ssimpson6
10-03-2006 09:35 PM
Medic 13
Modular V10 (6.8l)
03-21-2002 08:28 PM
Quick Reply: rattle
