1996 f250 5.8l 5speed m lack of acc/none in 5th gear
Truck was idleing high but had no acceleration so I reset the KAM and it helped with 1st through 3rd gear acceleration but have none acc. In 5th. Not really sure what it could be. I checked spark plugs no cracks but it was off recomended gap so I reset them and cleaned the carbon buildup. Plan on replacing them this friday. Do y'all think that they could be the problem??
I don't have away to pull codes and my CEL is out I believe. today I realized it also has a miss and if I unplug the map sensor the truck idles down to the correct idle and shows that all timing is correct. Does the MAP have anthing to do with spark?
You cannot check the spark while the computer has control of it, as it will vary the spark all over the place to help smooth the idle. You must unplug the SPOUT connector before checking timing.
You don't need a code reader to pull codes either, just a paperclip.
Oh... Ok thank you I'll retest it tomorrow after I run the codes
I'd definitely start with the TPS. Pay careful attention to the TPS wires too, it's fairly common to find the TPS wires chaffed with bare copper exposed.
Will do gonna check it tonight had to find a wiring diagram to know witch wires to test resistance in. Going to try to get a replacement once im sure its not exposed wires and in fact the sensor bad
I replaced tps and that got rid of that code still showing 327 so I tested sensor and it's bad as well so today I'll change that and see if I get the all clear to test timing
