NEW VIBRATION OR HOPPING TSB
Looks like a floating weight. I imagine that the mass of the chunk of steel simply behaves as a dampener, sorta like noise canceling headphones. When vibration hits it, the weight is heavy enough and free floating so that it would absorb the pulse and provide "equal and opposite reaction".
Pretty cool and maybe with a couple more pics I could make one for a lot less than $300.
Now again, this is only a Redneck guess and assumption.
I haven't read the other thread but a couple of questions:
Is the bouncing only when towing?
Is it obvious it's from the rear or does it also feel like it could be the front?
Mine has a shake at about 60mph but I was figuring that was the cupped front tires (likely is).
Player,
In my case, it is actually reduced somewhat when I tow, but it is still there. It is definitely in the rear, don't even feel any vibe in the steering wheel.
I hear ya..... I've waited for 6 years! I still hold little faith that this will fix it since they tried this back in 2005-2007 with a slightly different part number damper...
I have chased this issue with new tires trying 3 different brands. All of which were balanced a few times before moving on to another brand. Discount Tire was great in working with me.
I have found that I can adjust tire pressure and the setting on my Rancho 9000 shocks to lessen the feel, but it does still occur.
Towing our 5th wheel doesn't seem to either increase or lessen the feel.
My only complaint about the back order is that the part is due in to the dealer two weeks after we depart for an extended RV venture so it will be late Oct or early Nov before I can get it installed.
TSB
My 2016 has no symptoms or vibration at all , any speed. Going to do it anyway,
13,000 miles on odometer, 6,000 of which was towing 26 travel trailer through the Rockies in BC.
Really like the Engine brake going down mountains, never had to touch the brakes and it would maintain speed.
SO far very happy with truck
#29
TSB Completed
I was able to get my '16 longbed vibration thing added today. My local dealership had one in stock. In the two miles home at 42-50 mph, I can say that has eliminated 99.5% of the hopping that previous occurred. I am pleased!
Pics and video of how it works...the device actually floats (moves in 3 dimensions as well as rotational). See video as well.
Mounting bolts from the inside of frame well. Looks like they may have reused these bolts. not sure what exactly was here prior. Didn't take a picture prior.
View from below. Four rubber pads prevent the mass from striking sides. Mass supported by round rubber bushings.
Side View drivers side. Front to the left.
Video:
Video:
#30
