Weight Distributing Hitch?
But, all that is done and all that is left is to mow the yard.
I tow boats around that weight all the time and never once felt like I needed a WDH. I brought my friends boat from Houston TX to Racine WI a couple years ago. The dealer said it weighed 9,000 lbs & it towed just fine fine. Boats are balanced well on the trailers & don't seem to catch wind like enclosed trailers.
Are your brakes totally electric or are they electric over hydraulic? I've been thinking of converting mine.
2 common boat trailer failures are lug nuts and tires. I check mine every time I stop. I only go 50 ish miles the first timeout & check. If everything is good then I check at whenever we stop. If any nuts were loose or the tires seem too hot, I'll stop early again.
Yup, but boat trailer lights are different from regular lights. Water tight and made to be submerged. Nobody makes a marine-grade electric brake; and brake manufacturers specifically exclude electric brakes from marine use.
Just returned from towing my enclosed car trailer with my 32 Ford in it to and around the metro Detroit area and back. A little over 6,000 lbs. and no WDH. No issues at all. Just normal buffeting when around semis. Not even close to making me nervous. I never had anyone flash the truck assuming my brights were on. Truck is basically level hooked to the trailer. Going up I showed 8.9 mpg on the computer. 10.1 on the way back (different route).
Forgetting the junction box on the tongue, which doesn't get dunked, the only electrical part of electric brakes that gets doused is the electromagnet. Period. And it is potted with nothing for water to corrode or otherwise cause problems. Just a coil of wire with a wire in and one out, all encased in epoxy.
Sounds like a plan Gary. Our boat is a bit lighter than yours, about 3,500 lbs altogether. No noticeable squat, and I'm absolutely certain the tongue isn't over 300 lbs. I/Os are heavy though, our 4.3L/Alpha 1 combo weighs just north of 1,000 lbs. Maybe 180-200ish on the tongue, and it tows great.
Andrew Joyce
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
15
10-24-2015 01:16 AM
Ferguson65
03-25-2007 07:47 AM
dana_wildcat
07-29-2005 09:19 PM
SmittySD250
Toy Hauler Towing; Fifth Wheel & Bumper Pull
09-23-2003 01:08 PM
