1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 front axle problem
Old 08-03-2016, 11:25 PM
Tbanks1382's Avatar
Tbanks1382
Tbanks1382 is offline
Trailering
My '01 super duty sounds like a bad ball joint. I checked the ball joints and they look good. However I found on the drivers side there is what looks like a dust seal that is hanging around the axle. It's hanging both near the axle tube and the hub side. When I jack it up and try to shake the wheel everything feels solid. Any ideas what this is? Should it be replaced ASAP?
Old 08-04-2016, 12:07 AM
Squisher's Avatar
Squisher
Squisher is offline
It sounds like the outer dust seal on the axle tube. But a pic would help. It should be replaced to keep crud out of the axle tube but it's not critical and wouldn't sound like a bad balljoint. With the truck jacked up take the wheel off and get a good pry bar in there to check the ball joints for play.
If it's more of a rattle you're hearing in the front check your sway bar links and bushing.
Old 08-04-2016, 04:46 AM
redford's Avatar
redford
redford is offline
Received 1,561 Likes on 909 Posts
That is pretty normal. My dust seals have been hanging loose for years.
Old 08-04-2016, 06:31 AM
seemoremud's Avatar
seemoremud
seemoremud is offline
Better check the spindle bearings also. Check for excessive play in the shaft by grabbing the u-joint ears and seeing how much the shaft will "wallow" inside the knuckle. On the 01 I just traded off the pass side spindle bearing was bad, caused that seal to fail, then let the shaft droop down until the caps of the u-joints would touch the ball joints, occassionally that hub would grab at hoghway speeds, causing the shaft to turn and some pretty scary sounding noise.
Old 08-04-2016, 12:31 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Unless your goin muddin up past the axles dont worry about replacing the dust/crud seal until you have to remove the shafts for hub replacement. Just cut them off and go. Common prob. They redesigned them on the 11s I believe. Mine has 60K on it seals intact. The redesign I believe is backwards compatible, in other words should fit the 01
Old 04-18-2017, 05:33 PM
Crick07's Avatar
Crick07
Crick07 is offline
Wrong post.
jbounds
17
01-03-2015 12:41 PM
jayjjcc
04-01-2013 10:44 AM
rbsample
04-04-2011 07:44 PM
ganzey
01-24-2011 01:14 PM
LAblover324
06-11-2009 02:43 PM
Quick Reply: 2001 front axle problem
