04 f350 with an 03 6.0 P0275 cylinder 5 contribution code only when hot with rough id
I have an 04 f350 with an 03 6.0 motor. Truck started running very rough a two weeks ago. Checked codes and found p0274 and p0275. Both codes are for cylinder 5. I replaced #5 injector and truck ran like normal for a few days then began to miss again when operating temperature hits about 187+. It will show code p0275 once hot as it misses. When cold runs fine, starts fine. No smoke. Any thoughts??? Could I have put In a bad injector? It was purchased from AutoZone...
Don't feel to bad a injector was cheap lessen
Some poor folks here come after 10K plus lessens
3C3Z 9E527 ECRM / 1878282C91-----------------------------------Injector: (2003/2004 (04 Built Before 9/23/03))*
4C3Z 9E527 BRM / 1845150C92 -----------------------------------Injector: (2004/2005/2006/2007 (04 Built On or After 9/23/03))*
http://parts.autonationfordwhitebear...-3?parent=1073
Click it^^its early inject OEM
If you have an android phone get an ELM 327 Bluetooth adapter from Amazon or ebay and download the Torque app or FORScan app.. I use both. You can search on the forums for Torque Pro and find a lot of helpful information. The app costs $4.99 and you can find adapters from $10 to over $100. The BAFX adapter from Amazon is a good one for around $25.
Thanks jmaskew! I'll likely get one on order. Has anyone seen just one channel drop out on a ficm though, only effecting one cylinder? I just find it odd cylinder 5 keeps coming up and only when hot. No coolant loss, no smoke, starts great cold...Thinking about getting it to a Ford dealer at this point.
I suppose it's possible once things heat up the FICM is acting up and starving #5 for some reason. Perhaps a solder joint that opens up just enough with some heat? I guess the only way to rule the FICM out is to try a good known unit, or send yours in for a once over. Any idea if the FICM has ever been worked on?
